Shaking in Overdrive
Old Dec 20, 2018 | 02:39 PM
JYost17's Avatar
JYost17
I’m having quite a few problems with my 96 f250. It has the E40D tranny. At 45-50 in overdrive at low rpms the truck shakes pretty bad and the speedo bounces at 50-60mph but if I shut overdrive off no shaking and speedo goes back to normal. The other day it went into limb mode with od light flashing and hard shifting and check engine light came on as well as the speedo and odometer went dead. I replaced the VSS 3 times before. Any ideas?
Old Dec 20, 2018 | 03:19 PM
Conanski's Avatar
Conanski
Definitely pull codes and post up what you get. The speedo could be the root of all your problems, has it come back to life since? If not check fuses too.
Old Dec 20, 2018 | 07:19 PM
JYost17's Avatar
JYost17
I’ll try to pull the codes tomorrow. When I shut the truck off and started back up everything was fine but the Speedo still bounces and the truck still shakes at low rpms in OD
Brandon_f250
Sep 23, 2018 10:55 AM
mudman1
17
Mar 13, 2018 06:14 PM
M4TTDUFFY
Sep 15, 2017 10:28 AM
gpacster
15
Aug 16, 2015 11:01 AM
adamzelazowski
Apr 1, 2009 08:19 AM
