Help, no start after oil cooler change
So I just finished putting the truck back together after replacing the oil cooler, egr cooler, #1 injector, stc fitting, standpipes etc. I have no power. No lights nadda. My battery voltage is 13 volts. Where is the main fuse at. What else would you look for.
Thanks
Thanks
So I unbolted the fuse panel and checked for voltage at the power wire on the side. No voltage. This is definitely odd. When power comes off the battery and goes down where does it go first? I also checked the ficm relay and no voltage. I also checked the obdII connector, I think the bottom right terminal is supposed to be battery power and no voltage there either.
Oh and where is the pcm located
X2 here^^^^^^^^^
Only other thing I would add is clean the Main grounds coming off the Battery negative posts where they attatch at Engine by A/C Compressor and to the Frame at Power steering pump
In addition there are Fusable Links in quite a few of them wires coming off the Batterys
The PCM sits by the Driverside Battery check all its plugs
So does main power go to the fuse box first then distribute from there?
The only ground I remember removing is the one on the heat shield under the ficm
Okay, please post EVERY electrical connector you disconnected. If this truck was running perfectly without any issues prior to the work, you've left something disconnected. It's that simple. Did you disconnect both batteries when you did the work? Let's start there. The passenger side battery is where the alternator and GPCM get their B+. The driver side battery positive terminal is where the main B+ supply goes to the interior. I suspect you have an issue with that terminal.
Ok so I disconnected negative terminal on passenger side battery and disconnected alternator.
disconnected drivers side battery and removed completely.
Disconnected main engine wiring harness and all associated sensors and removed from engine
Disconnected and removed fuel injector harness
removed ficm
You said interior gets power from drivers side battery. You might be onto something here. did I forget to attach a terminal to the + side? Right now I just have the battery cable attached going to the passenger side batt.
Great Info right there^^Learned somthing today
