Help, no start after oil cooler change
#91
#93
#94
Again, I can not express enough how greatful I am for the help!!!
took awhile to start\batteries were dead. And just my luck, my charger died to so I had to get another one. But its running again. In the am, I'll check to make sure fluids are no longer mixing, which why I changed the oil cooler.
I did get a fuel level sensor error, so I guess that will be next.
I am relieved to have my wheels back!
thank you
thank you
thank you
thank you
thank you
thank you
#95
thank you
thank you
thank you
thank you
thank you
thank you
Clear it and see if it comes Back remember we was Pullen fuses and turning key on could be from the way we Diagnose the truck
I bet its OK
Put that charger on trickle charge and let it go tonight this of coarse is assuming its has an Auto-ShutOFF feature
#96
ran the truck today, run time was about an hour and 15 min or so total. everything seamed ok, except I noticed the temps between the Engine oil and tyhe coolant stayed vry close to one another. Is that norm?
I still see the Choc milk look in the coolant but the oil, so far seams normal. I know that coolant in the oil can lead to a lot of probs. What is the best way to keep an eye on that? And should I find a way to flush the coolant with pressure vs just a gravity flow?
#97
on
to flush the cooling system go out and get 2 gallons of simple green using about a 1/3 gallon at a time. remove the t-stat and run rpm at about 1200 for an hour keeping an eye on the temps. open drain valve on radiator and stick garden hose in degas bottle.
repeat till clean. go drive it 10-15 miles and repeat as needed.
make sure to follow all laws in reguards to desposal of the drained liquid
#98
All sounds Good ECT and EOT should stay Close to same temp to one another (You dont want EOT to get more than 15* Higher temp than Coolant) Thats the FORD Spec
Search and read Oil Cooler Health
Just do like Cheezit says and Flush the Cooling system Till Oil is Cleared out and GONE
Keep an Eye on the Coolant Hoses the Oil will make them Fail premature from what I hear
Get the Oil Flushed out the Coolant and should be Good to go
