air in the secondary filter bowl?
Without warning my 03 F250 6.0 with 75,000 miles on it wouldn't start.
1. Air? check!
2. Fuel? mmmmmmm...
Figuring fuel as the most likely prob, I quickly changed the 2 fuel filters and drained of any water (last done 2 months ago). Result...No start.
Opened the secondary filter to check for fuel. Result...has fuel. I turned key on without crank and plenty fuel cycling in but lots of air bubbles. After cycling a number of times and lots of diesel every where bubbles persist. rechecked seals on filter cap and drain plug...result bubbles.
Any suggestions?
It seems unlikely that the fuel lines between the water sepertator and secondary filter have a leak.
Any test or checks I could perform to find out where the leak is coming from?
1. Air? check!
2. Fuel? mmmmmmm...
Any suggestions?
The pressure seems to be coming in strong though.
I was able to get it started by leaving the key in on position for around 5-10 minutes and no problem since, though I am sure the issue will return. What would cause the pump to aerate the fuel?
I double checked both o' rings on HFCM and am monitoring everything around it for dripping fuel. I assume when vehicle is running it will pull air in and when off small amounts of diesel will leak. I will closely inspect the cover plate and to ensure a good sill.
Its been about 5 days since initial prob and no repeat symptoms or fuel seeping. Like it never happened? Thanks for all the advice!
hank89
05-13-2013 04:05 PM
