Well heck, you know all this stuff already! I'm preachin' to the choir. Never mind... You're a nerd Yahiko! That's a compliment, btw
Had I been thinking ahead I would of put that to good use. Still need to check the starter in there also.
Not a bad sermon to preach now and then.......
So very true.
The thing that made me think that the cable had some nasties growing down under the insulation was that
it had failed between the battery clamp and the 2ga connection.
So now my only question is because I have the time and noting really going on. Should I go ahead and just pull the
starter and have it tested or wait to see if it works with the new cable. Likely I will be board and just yank it out.
