My appologies up front if I am asking a question that has been asked a bazillion times. I searched a few pages and FAQ and did not see my question which is: What is the proper way to charge a 6 volt positve ground battery? I have read that you charge it just like any other battery, but with a 6 volt charger.
I also have read that you put the Negative charger cable on the Negative battery terminal and the positive charging cable to ground such as to the frame.
Please set me straight.
The background of the vehicle is: 1953 Panel, 50th aniversary additon, 21000 orginal miles, all orginal from water pumps to upholstery, un-molested except for a repaint, driven off the assembly line by my grandfather...as the story goes. Thanks again for the help.
Agreed ^^^. I currently have three Optima 6v batteries. Each one is attached to a Battery Tender Jr. to keep it charged whenever not in use. I simply attach the positive cable to the positive post and the negative cable to the negative post. I'm at about 6.3v at each battery.
If you don't have a good battery charger, I recommend getting the Battery Tender. Like I said, I have the Jr. model and it works great. I was able to buy three of them on Amazon for the price of two at the local retail store, plus I got free shipping.
Iused a battery tender until I replaced both of my regular 6-volt batteries. Since then, (3+ years) I have started both cars about every 2-3 weeks, and they are both starting fine. :-) Jag
You bring up another question and maybe another post but I will try it here...This truck sits for months at a time, if not a year sometimes, in storage. I read once in Hot Rod or somewhere that there are head plugs that you can remove to pre-lub the cylinders prior to cranking after sitting for long periods. Is that true and/or are there other things we should do prior to this type of "cold start" that would help protect it?
Simple thing to remember is, you're charging the battery. + to +, - to -. And there is not really any reason to disconnect the battery to charge it. Sounds like a great truck..
I would be more concern with the ethanol laced fuel of today and the deterioration to the fuel system. I would run stabel or other fuel conditioner in the fuel tank. The Echo brand 2 cycle oil that I use in my chainsaw and other two cycle equipment has lubricant and fuel stabilizer in it. I think I might look into something like that in the fuel. Not much trouble to pull the spark plugs on the flathead and pour a bit of oil in prior to starting.
Probably overthinking it but the "Positive Ground" concept I was unsure off and did not want to blow up the battery. Thanks again.
The truck belongs to my uncle who lives on the West coast. He usually drives it when he comes back to Illinois. A little gas in the carb, choke and few cranks it starts every time. It was used as a flower truck for my grandfathers Funeral Home so it saw little trips here and there and has been kept inside most of it's life. Very little rust on frame and zero on body. I grew as a kid pretending to drive it by pumping the clutch which made a squeak sound.
I am in the diesels right now, but would love to own this truck. Maybe some day. In couple of weekends I will be where the truck is and I can take some pics and post them. It really is the definition of a barn find, except it has always been found. LOL
I believe that you are talking about removing the spark plugs to pre lube the cylinders. I have heard of people doing that for engines that have been setting for years, but not engines in running condition inside out of the rain.
Is it possible to go out and start the engine every once in a while? Jag
Long story short, yes, it will now be started at least monthly. So it should really not be an issue going forward. I will start it like we always do.
Thanks for that info also. Do you run a "lead" additive also?
If the truck has been sitting for a week or more i'll "pre-lube" the motor by pushing the starter button with the ignition switch off, letting it crank over a few times. gets oil circulated, and pumped up into the valve train and such. after a few cranks, turn the key to ON and off we go. Doin that you might even get to avoid the gas down the carb bit as the fuel pump will be filling the carb's float bowl
No, I do not run lead additive. None of my old Fords except one tractor works very hard. Side note, I start and bring to operating temperature every piece of internal combustion engined piece of equipment at least monthly.
