Electrical Question
Old Jan 7, 2013 | 09:52 PM
tyrantsparky's Avatar
tyrantsparky
Electrical Question
Any thoughts on why there seems to be a heavy draw on my battery (according to the gauge) that slowly goes down as the truck runs for a bit. It never goes into the plus side as if battery may be recharging. I tested the alternator by pulling the negative off while it was running and it did not die which is a good sign. Any thoughts?
Old Jan 8, 2013 | 05:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Discharging battery: Did you install the battery in backwards? 1956 thru today: FoMoCo vehicles are 12V negative ground.
Did you buy a new battery recently? The batteries used in GM/ChryCo vehicles have the terminals reversed.
Some people don't pay attention to the location of their trucks battery terminals, buy one of these batteries.
Then they hook the cables up backwards: Positive cable to the negative (-) terminal. Negative cable to the positive (+) terminal.
Old Jan 8, 2013 | 06:11 AM
tyrantsparky
I have the battery in the right way. Positive to the solenoid, negative to the block
Old Jan 8, 2013 | 10:16 AM
hiball3985's Avatar
hiball3985
You have an alternator or an original generator?
Old Jan 8, 2013 | 11:08 AM
tyrantsparky
There is an alternator in the truck. Like I mentioned, I had disconnected the battery while it was running and the truck kept running so I am not too suspicious of the alternator. It's weird. The battery does not run down fast either. I just put in a new one so we will see how it holds up
Old Jan 8, 2013 | 11:18 AM
hiball3985's Avatar
hiball3985
Hopefully it was just a bad battery, good luck.
Old Jan 8, 2013 | 12:28 PM
tyrantsparky
Actually this is happening with the new battery. I was just wondering if I should be concerned with such a big load when I start it up. Maybe there is no real problem
Old Jan 8, 2013 | 02:32 PM
SuperSabre's Avatar
SuperSabre
Have you tried replacing your voltage regulator? Sounds like a possible problem candidate to me. Good luck!
Old Jan 8, 2013 | 05:03 PM
hiball3985's Avatar
hiball3985
After you start it the needle should go to the + side of the gauge and then return slowly toward the center as the battery charges back up.
Old Jan 8, 2013 | 05:39 PM
tyrantsparky
That's what I thought. It starts around -26 to -30 and then slowly hovers around zero maybe a little in the negative but I don't think it has ever been in the positive. Ill watch it. Like I said before it runs with the battery negative cable disconnected. Maybe it is the voltage regulator.
Old Jan 8, 2013 | 06:35 PM
hiball3985's Avatar
hiball3985
It sounds like the gauge is wired backwards. Doesn't your alternator have a built in regulator or is it an early one?
Old Jan 8, 2013 | 06:43 PM
NumberDummy
If the amp gauge needle shows a discharge, it won't be too long before the battery will be as dead as Julius Caesar.
Amp gauge needles hardly move if working properly. Engine off, headlamps on, wait 5 minutes. Then start engine, gauge needle should move to the charge side.
btw: When you installed alternator, did you replace generator ammeter gauge with one for an alternator? They're different as are the voltage regulators.
Old Jan 8, 2013 | 08:27 PM
tyrantsparky
I apologize for my greenness, and I appreciate all of your help and insight. To be honest, it was installed before I bought it. I don't think there is any sort of regulator installed and am unsure of any gauge change out.
Old Jan 8, 2013 | 08:29 PM
tyrantsparky
If I were to throw a meter on the battery, what should it be reading if it is still healthy?
Old Jan 8, 2013 | 08:49 PM
hiball3985's Avatar
hiball3985
When someone else has done the changes it's hard telling what they did. I'm not sure how they would have wired the alternator to the original gauge.
If the battery is fully charged you should get at least 12V. If you check it running it may be as high as 14.
