Front Springs
Old May 6, 2012 | 09:27 PM
1972RedNeck's Avatar
1972RedNeck
Front Springs
In my parts catalog, It shows Part #'s
C5TZ5310C - 1965/1966 F250 4X4 1350 Lbs. 6 Leaves
C5TZ5310D - 1965/1966 F250 4X4 1550 Lbs. 6 Leaves
I have the lighter springs. I am looking to upgrade to the heavier springs.
THIS WEBSITE will build them (the website won't but you get what I mean). They list that they have 7 springs.
Does the above place just add a spring to the light stack or does the parts book have a misprint?
Old May 6, 2012 | 09:38 PM
garbz2's Avatar
garbz2
Dude your truck is almost 50 years old. Have springs made at a shop tell them what you want.
"I want a six leaf in the 1550# range."
No problem, what is the leaf width, eye to eye dimension and center line of front eye to pin?
"C5TZ5310D"
Huh? do you want 1550# leafs or not?.........
Parts books are meaningless in the aftermarket.......
Why do you want the heavier leafs for? a more rustic Conestoga buckboard ride? Or did you actually add 500 pounds of stuff to the rear end?
Garbz
Garbz
Old May 6, 2012 | 09:41 PM
schoo's Avatar
schoo
my 64 f250 4wd has 6springs just tookem out today going to sacramento monday for rebend or what ever they do toem
neighbor's thinks i should ad a spring! idon't know?
roy
Old May 7, 2012 | 10:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by schoo
my 64 f250 4wd has 6 springs just took em out today going to sacramento monday to have them re-arched and replace the bushings.
And what is Sacramento Vintage Ford going to do with your springs? They're going to send them out to a spring shop and then mark up whatever the price is.
Eliminate the middleman, find a spring shop in your area and pay less.
Old May 7, 2012 | 11:59 AM
C G B's Avatar
C G B
Garbz
I had to laugh when I read this...
Old May 7, 2012 | 01:30 PM
schoo's Avatar
schoo
should be more specific west sac spring they replaced( it was broken main leaf)a spring back late 70's on a 60 4x4 i had owner wasout today don't know$$
i'll go with his ideas for re-arc on front
the backs just clean paint, new pins,bushings & shakles(one was cracked and almost worn through, oblong bad maintance on my part & po
roy
Old May 7, 2012 | 01:34 PM
NumberDummy
i'll go with his ideas for rebend on front.
Not bending, per se: Spring shops heat the springs then re-arc them. If you tried bending a spring without heating it, it would break in two.
Old May 7, 2012 | 01:57 PM
schoo's Avatar
schoo
maybe i should get coils for the front then red could have more leafs for his(like chevvv work like a truck ride like a horse)ride
i made a correction on my other post for bill
Sapple
Feb 22, 2018 04:57 PM
kingbee
WTB - Parts & other
Jun 16, 2016 02:20 PM
dullchrome
Jul 21, 2014 10:17 PM
1964FORDTUF
Jun 11, 2014 08:02 AM
64f-100guy
Nov 27, 2011 05:45 PM
