headlights fading!!
Old May 7, 2012 | 09:43 AM
sweetiepie1's Avatar
sweetiepie1
headlights fading!!
Why would my headlights fade from bright to dim in a pattern like a slow turn signal? This on a '66 F350 dually.....
Old May 7, 2012 | 12:05 PM
C G B's Avatar
C G B
Do they get dimmer when you use other electrical things, or start bright and get dim as the vehicle runs?
Id look at battery, alternator, switch in that order.
Old May 7, 2012 | 01:08 PM
bertha66's Avatar
bertha66
Also check the ground wires for rust around where they bolt to the core support.
Old May 7, 2012 | 02:35 PM
sweetiepie1
new battery, but will go down the list otherwise.....Thanks, y'all
Old May 7, 2012 | 03:50 PM
tbm3fan's Avatar
tbm3fan
Also, when on, if you have a volt meter then check the connection at the head lamp to see what your voltage is at that point. It won't be 12V but if really low then you would be leaking voltage somewhere.
Loosescrews
Apr 1, 2018 10:32 PM
NickOlsen53
25
Jan 14, 2014 08:32 PM
ford f-200
Electrical Systems/Wiring
Jan 20, 2009 04:46 PM
petelynch
Jun 15, 2007 12:57 PM
grandads76
May 15, 2007 01:37 PM
