Early 60s ford Leafs question
Old Feb 21, 2018 | 12:49 PM
Sapple's Avatar
Sapple
I have a 62 f250 4x4 and a 64/5 f100 4x4, looking for front leaf springs and cant seem to find them anywhere! They are roughly 48 eyelit to eyelit and 2.5inch wide on both trucks does this seem right or can anyone point me in the right direction
Old Feb 21, 2018 | 01:27 PM
'65Ford's Avatar
'65Ford
Eaton Detroit Spring can probably make them to spec for you. Not cheap, but can't complain with the quality of the rear springs I bought 10 years ago.
Old Feb 21, 2018 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Sapple
I have a 62 F250 4x4 and a 64/65 F100 4x4, looking for front leaf springs and cant seem to find them anywhere!
1961/64 F250 4WD front springs: 2.50" wide, 24.00" > > eye bolt < < 24.00"
C1TT-5310-AG .. 6 Leaf Front Spring with 1,350 lbs. load rate.
C1TT-5310-AH .. 6 Leaf Front Spring with 1,550 lbs. load rate.
No Ford dealer or obsolete parts vendor has either spring.
1961/64 F100 4WD uses different front springs than 1965 F100 4WD
Old Feb 22, 2018 | 01:56 PM
Tedster9's Avatar
Tedster9
Sapple, welcome to FTE
Keep in mind leaf springs are something that any large truck shop local can often make for you, at a decent price. Shipping charges for bulky, heavy items can add up quick, so they will be competitive right there.
Also keep in mind the rubber bushings need replacing, as they have turned to stone by now. The fronts are inside the truck frame and can be a real SOB to extract.
Old Feb 22, 2018 | 04:57 PM
willowbilly3's Avatar
willowbilly3
20 years ago in Anchorage, we had a great spring shop and they were cheap. also used to send leaf spring 4x4s over to get leveled back up if they were sagging. Maybe you could find such a shop in your area.
If you are buying used, or new I guess, make sure the center hole is in the right place. I've had customers bring junkyard springs that were only a couple years different and measured right for length but wouldn't work because the center hole was off.
Amphihauler
Nov 15, 2017 11:47 AM
Chad63F250
13
Jun 8, 2017 07:34 PM
1964FORDTUF
Jun 11, 2014 08:02 AM
Tidefan88
Jun 13, 2011 11:06 AM
Dood
Feb 16, 2009 12:08 PM
