Tune-Up Questions
Old May 5, 2012 | 02:18 PM
oldfords4me's Avatar
oldfords4me
Tune-Up Questions
Hello! .. was attempting to do a 'tune-up' on the truck. (76 F100 360 v8 2bl 2wd)... Have gotten..
Plugs (is the gap .044?)
Plug Wires
Roter Button
Distributer Cap
.. is there anything else i should focus on and are there any pitfalls i should be looking out for, etc while i take this on?
Thank you!!
Old May 5, 2012 | 03:03 PM
HIO Silver's Avatar
HIO Silver
I apply/smear dielectric grease on the plug boots and terminals to stave away moisture and make it easier down the road to pull off.
... mark and tag the plug wires so ya don't mix'em up and get a misfire. Soooo many times peeps forget which goes to what.
Old May 5, 2012 | 06:38 PM
Ioki's Avatar
Ioki
Air and fuel filters been changed recently?
And check the air pressure in the tires, it's easy to forget but it makes a difference in MPG.
Old May 5, 2012 | 08:06 PM
HIO Silver's Avatar
HIO Silver
If ya just bought the rig, replace ALL the fluids and filters... engine, trans, rear axle, brake fluid, coolant, etc. That way YOU know the last time it was done.
Old May 6, 2012 | 11:51 AM
oldfords4me
Thank you both! .. was wondering if i should do the points as well since i was already doing the cap and roter...
Old May 6, 2012 | 11:59 AM
79 f350ts's Avatar
79 f350ts
76 should have duraspark ign. so wouldnt have points
Old May 6, 2012 | 12:00 PM
alans77crew's Avatar
alans77crew
Isn't 44 a little wide for point ignition that would be for electronic I think I would go .36 to.38 and .18 on the points or convert it to pertronix electronic ignition
Old May 6, 2012 | 01:02 PM
oldfords4me
Sort of a novice with some of this .. so my apologies at the 'stupid questions' ...
.044 is what they told me at the parts store? .. I'll double check the manual and such on that one ...
How would i be able to tell about he duraspark ignition?
thanks again ...
Old May 6, 2012 | 01:30 PM
alans77crew
you would have the ignition box on the driver side up towards the hood and since its a 76 it could very well have electronic ignition in that case no points to change and that gap would be correct also the only stupid question is the one that wasn't asked!!!!thats how we learn
Old May 6, 2012 | 01:56 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I would do fuel and air filters, look close at the belts, summers coming and you don't want to lose a belt and overheat, test coolant, throw a timing light on it and look at that, I like to just check every thing, like brake fluid, power steering, battey cables, lube the clutch and steering linkages, lube the carb linkage, grease the front end and u joints, look at the brake pad lining, lube the hood hinges, lube the hood latch, lube the door latches & hinges, maybe even pull the door panel and lube the window regulators, lube the glove box door, To me a Tune up and service is a lot more than an oil change, vehicles need a lot of care and I like to keep mine really nice. Usually my trucks are sold for more than I paid for them.
Old May 6, 2012 | 06:58 PM
wyckedcombo17's Avatar
wyckedcombo17
.044 is right if you have electronic ignition, like they've all said, and you'll have a the box that says "motorcraft" on it on the fenderwell with a bunch of wires coming out of it.
If you have points, you'll see something like this in the bottom of the dizzy:
If you have duraspark II electronic ignition, the bottom of your dizzy will look like this:
Old May 6, 2012 | 07:03 PM
84espy's Avatar
84espy
Also, check the vacuum lines for cracks and have a Chilton or Haynes manual close by. Can't tell you how many times I have had to reach for the book for reference. Even for firing order of the distributor.
Old May 6, 2012 | 07:11 PM
PapaBearYuma's Avatar
PapaBearYuma
I (vaguely) remember setting points and replacing condensors!
Remember, NumberDummy says that lubing the speedo cable is a maintenance thing...
Old May 6, 2012 | 08:22 PM
oldfords4me
Great info. Thank you all for being helpful. Have manual in hand and i'm sure i'll be asking for additional help down the road. Thanks again all! ..
Old May 10, 2012 | 02:59 PM
oldfords4me
So i have a GP Sorensen electronic ignition ... Should i replace it with a BWD Select or something else?
ZombieSlayer
1978 - 1996 Big Bronco
Jan 8, 2014 07:33 AM
Spotty
1997 - 2003 F150
Jan 5, 2009 12:04 PM
JohnAW
General Automotive Discussion
Sep 18, 2005 11:43 AM
JustinH
Modular V8 (4.6L, 5.4L)
Jul 7, 2004 03:34 PM
Fatstrat
13
May 4, 2004 01:23 PM
