Fuel level errors
Old May 5, 2012 | 12:46 AM
Yahiko's Avatar
Yahiko
Fuel level errors
I have been getting some intermittent fuel level errors. Some times it will drop ot empty other times it will go full. It sets a code I forgot to note it.
But I can clear it with my Snap-on scan tool.
The question is do I have a dirty level sensor or a bad one?
If it is just dirty can I use Chevron Techron to clean it?
At some point I will have to drop the tank because the sender is
weeping around the edge. Bad tank seal ring I think.
2006 F-350 Powerstroke 6.0L Crew Cab Long Bed 147K miles
Thank You in advance for the help
Sean
Old May 5, 2012 | 07:06 AM
bismic's Avatar
bismic
I assume you have checked the wiring/connector to the level sensor and it is OK?
Old May 5, 2012 | 08:40 AM
cheezit's Avatar
cheezit
p0460 and or p0463. there is a bulliten about a reflash that may cure it. imo its a bad sender.
Old May 5, 2012 | 10:45 AM
Yahiko's Avatar
Yahiko
Hi,
Have not been able to get under it. Been raining on and off here when the problem
showed up the first time. I cleared the codes and it was ok for a few weeks that showed up again yesterday.
Code wise I got this the first time.
b1201: fuel sender circuit fault
p0463:fuel level sensor high input
I only got the p0463 yesterday
Snap-on MT2500
I know I will have to replace that seal ring because of the weep
and I should have about 1/3 tank or a bit more.
I may pull the tank and have a look today if it stays dry.
I'll let you know
Thanks for the help.
Does the Chevron Techron cleaner work or is that just snake oil?
Sean
Old May 5, 2012 | 11:02 AM
cheezit's Avatar
cheezit
Ive tried to fix a few with the techron... never had any luck ymmv
Old May 5, 2012 | 05:57 PM
Yahiko's Avatar
Yahiko
It's raining again and I snapped a t-50 on the bed bolts.
So I sprayed they with some ACF-50 and cleaned the ones I
got out. I will retry this Sunday.
Old May 5, 2012 | 07:23 PM
richsoucie's Avatar
richsoucie
youre going to have to cut them off they wont come out no matter how hard you try better to just drop the tank
Old May 5, 2012 | 08:14 PM
Sarge261's Avatar
Sarge261
I tried to clean mine with Techron, it worked for 1 tank full...I still need to drop the tank and replace the sensor.
Sarge
Old May 5, 2012 | 08:40 PM
Yahiko's Avatar
Yahiko
Well I went to Sears and got a new (most likely made in China) T-50 to replace the broken one. The one good thing is all the bolts that are stuck are clear of any thing that will burn/melt or go boom. I will heat the clip nuts (or are they called J nuts) up a few 100 F. The one really nice thing is the spray in bed liner was not sprayed on the bolts. I don't want to cut the bolts the last time Ford wanted $12.00 for each nut and they were just the normal nut with attached washer $4.00 at the local nut and bolt place the stupid bolts were even more money.
The reason for all this extra work is I don't have any help and my tranny jack went away with the house fire and never got replaced. And the only other person is my mom @ 85 years. Yes I know I gave away a lady's age.
I guess if I go this fas I should take photos to post if anyone ever asks .
Long winded post
Last thing are the fuel line disconnects the type that need the tool you slide into the fitting or the other one that you just depress the green or yellow tab.
Thanks
Sean
Old May 5, 2012 | 08:57 PM
bnelson2444's Avatar
bnelson2444
I have a 1995 with 2 tanks . And it gets to a certain level and both will act up . Is it probably the sensors ? If so are they on the pumps ?can you just replace the sensors or do you have to replace them
Spktyr
May 20, 2012 09:01 AM
429poweredf350
Apr 20, 2011 03:10 PM
Fire_420
Feb 3, 2010 03:44 PM
nd925
1983 - 2012 Ranger & B-Series
Sep 23, 2008 03:13 PM
REELNAUTI4U
General Diesel Discussion
Oct 24, 2007 02:28 AM
