Electronic Problem??
Old May 5, 2012 | 07:31 PM
sc6.0diesel250's Avatar
sc6.0diesel250
Hey all im new to the forum and love it already. My 03 6.0 250 has some kind of electronic issue. It will crank up and run fine,idle fine, for about 30 seconds and then cut off like you turned it off by the key. Had someone put a computer tester on it and it read( V0105 lost communication with fuel injection control module)It started this problem instantly, nothing leading up to this prior. Any help would be appreciated!
<!-- / message -->
<!-- controls -->
Old May 5, 2012 | 07:48 PM
BLADE35's Avatar
BLADE35
Welcome to FTE
There are 3 plugs going to the FICM check those make shure there fulley plugged in
Wonder if someone took FICM out B4 and broke a Tab on the connector
Heres a Pic of the FICM and the 3 plugs its right under the coolant Bottle Bolted to the top the driverside valve cover
Old May 5, 2012 | 08:26 PM
sc6.0diesel250
Blade35 your awesome.Im at work till the am.I'll give it a try then.hopefully that will work for me. Thanks for your time.
Old May 5, 2012 | 09:05 PM
BLADE35's Avatar
BLADE35
U0105 Lost Communication With FICM
Study threw this in your free time great info in it
http://api.viglink.com/api/click?for...13362698927684
AustinChappell
Sep 17, 2018 01:53 PM
jimbonnet
Mar 24, 2018 04:44 PM
Miguel P
General Automotive Discussion
Sep 28, 2016 06:16 AM
Showpanther
52
Aug 31, 2012 02:21 PM
SteveBricks
S. California Chapter
29
Sep 30, 2008 08:14 PM
