Front Fuel Level Sender question
May 19, 2012 | 03:21 PM
Since I've owned my truck, the front fuel level sender/sensor has been dead. I scored a new Motorcraft one off eBay for cheap, so that's taken care of. What I am wondering is with the dual tank setup, do I still have to drop the tank to replace the sender on the front tank like you do with the rear one? Also, any advice on the task would be appreciated.
May 19, 2012 | 03:29 PM
You will have to drop the tank or lift the bed
May 19, 2012 | 04:37 PM
What was yours doing? Mine just goes up then down and so fourth...i have not looked into it yet...
May 19, 2012 | 08:17 PM
Mine was doing absolutely nothing - claims the tank is empty when it's full. Rear one reads fine.
May 19, 2012 | 09:13 PM
Quote:
Originally Posted by
fordman67
Mine just started doing this too. let us know what you find when you do decide to look into it.
May 19, 2012 | 10:06 PM
I did both my tanks last winter without pulling the bed, super PITA! My sending units were OK, both of the gaskets were leaking for a few years.
May 19, 2012 | 10:30 PM
Since it works fine on my rear tank i am pretty sure the sender is faulty....i might look into it after the rsk and fuel rebuild in the v.....
May 20, 2012 | 09:01 AM
mine started acting up after I had the plastic bezel off the dash.
Hiddencamper53
Apr 16, 2016 05:59 AM
stopp429
Feb 15, 2013 06:42 PM
4EyedTurd
Dec 20, 2012 11:49 PM
dakotajeep
Mar 12, 2008 09:35 PM
scozim
Jun 11, 2006 12:14 AM
100 ,
1968 ,
1995 ,
article ,
bronco ,
dashboard ,
diesel ,
ford ,
fuel ,
groups ,
lb ,
level ,
lose ,
powered ,
sender ,
support
