P0453 OBDII Help
Old Sep 23, 2008 | 09:27 AM
nd925's Avatar
nd925
P0453 OBDII Help
Where are all the good mechanics on Long Island? I'm getting a P0453 OBD code. I know what it is just don't have the time to mess with it. I brought the truck into a local shop here to have that fixed along with getting a NYS Inspection. Well, some new ball joints and a $450 bill and CEL is still on and no inspection. He reset the computer and said to drive it for a while and bring it back. The light came back on (no surprise there) and I need to get this thing inspected. Is there any way to trick the computer to clear the code long enough to pass the inspection? Maybe put a resistor some where or anything? I plan on fixing the problem but I need to get the inspection done asap. This is the second shop that seems like they don't want to have anything to do with fixing this problem.
Thanks in advance for any help.
Old Sep 23, 2008 | 10:10 AM
73f100shortbed's Avatar
73f100shortbed
I think you need to find a better shop. It is for the EVAP system, but without knowing the year or model of your truck I can't give you any other ideas.
Old Sep 23, 2008 | 12:05 PM
nd925's Avatar
nd925
Sorry, I knew I forgot something. 98 Ranger XLT 3.0. Thats the problem, I can't seem to find a shop that's willing to work on it. This is the second shop.
Old Sep 23, 2008 | 12:16 PM
Rockledge's Avatar
Rockledge
Diagnostic Trouble Code (DTC) P0453 indicates that Self-Test has detected a fuel tank pressure sensor (FTP) circuit input above the maximum limit.
Possible causes:
- FTP open.
- FTP short to VREF or VPWR.
- VREF shorted to VPWR.
- SIG RTN open.
- Damaged FTP sensor.
- Damaged PCM.
The FTP is located on top of the fuel tank. To replace it, the the Ford Manual states as follows:
1. Remove the fuel tank.
CAUTION: The fuel tank pressure sensor must be disengaged from the fuel tank before it can be removed. Failure to do so can cause damage to the fuel tank pressure sensor or the fuel tank.
2. Remove the fuel tank pressure sensor.
- Disconnect the electrical connector.
- Press down and rotate the fuel tank pressure sensor counterclockwise and remove it from the fuel tank.
Installation is the reverse of the removal procedure.
Old Sep 23, 2008 | 12:37 PM
73f100shortbed
I just looked up in Alldata, but Rockledge posted the info already for you
Old Sep 23, 2008 | 03:13 PM
nd925's Avatar
nd925
Thanks for the info guys. Follow up question, are there test points located some where to check the possible causes in Rockledge's reply or am I going to have to scour the truck? If there are test points where would they be located? Thanks again.
nitro94
1997 - 2003 F150
Dec 27, 2014 05:27 PM
vtgboss
Aug 29, 2014 07:46 AM
Sands77
Nov 13, 2013 05:39 PM
