Adjusting the door latch post so the door closes tighter works to cut down on wind noise. That's what I did on the one door that had a wind noise problem. They are adjustable for a reason.
On my SCab there are two torx bolts to loosen and then you can adjust it in and out,and up
and down. Sliding it in will give a tighter closure. Trial and error till you get it right.
Door latch post on rear door of Super Cab. Must be something simlar on door jam of
CC and Reg Cab.
