Door seal mod...
Old Apr 29, 2012 | 11:48 PM
nookiemonster55's Avatar
nookiemonster55
https://www.ford-trucks.com/forums/9...mod-video.html
there ya go.....
Old Apr 30, 2012 | 12:30 AM
smithrock's Avatar
smithrock
Originally Posted by nookiemonster55
.......and there it is! Thanks!
Old Apr 30, 2012 | 07:54 AM
Krazymaan's Avatar
Krazymaan
How much does OEM weatherstrip cost per door?
Old Apr 30, 2012 | 07:57 AM
JonathanN's Avatar
JonathanN
What exactly is surgical tubing? Is it softer rubber?
Old Apr 30, 2012 | 08:03 AM
honeydew's Avatar
honeydew
It's latex and does seem softer than rubber.
I used epic cowlick's method in the video except I used 303 aerospace protectant as lube instead of silicone spray.
Old Apr 30, 2012 | 08:07 AM
JonathanN's Avatar
JonathanN
Softer than that clear stuff from Lowes? No way I'm gonna use that stuff... WAY too hard! That surgical hose looks good. Probably softer than vacuum line I bet. Does that silicone dry up? I know, stupid question... I don't like powder (goes "poof" when you shut the doors) and I don't want any kinda oil that will stay in there. I'm thinking soapy water, but I don't know.
Old Apr 30, 2012 | 08:12 AM
honeydew's Avatar
honeydew
Yes, softer than that stuff.
Here is what I used: Amazon.com: 50 Feet Black Rubber Latex Tubing 3/8"OD 1/4"ID (#804R): Health & Personal Care
The 303 I used is like armor all but better and did not squeeze out or dry up. I recommend it, worked well and the seals will like it.
303 Products, Inc.: 303 Aerospace Protectant
Old Apr 30, 2012 | 08:23 AM
trekbasso's Avatar
trekbasso
[quote=JonathanN;11772833]Softer than that clear stuff from Lowes? No way I'm gonna use that stuff... WAY too hard! That surgical hose looks good. Probably softer than vacuum line I bet. Does that silicone dry up? I know, stupid question... I don't like powder (goes "poof" when you shut the doors) and I don't want any kinda oil that will stay in there. I'm thinking soapy water, but I don't know.[/quote
Generally no, not to the extent of powder. There is a carrier that will evaporate and leave a fine film, but shouldn't be "oily" or harm the rubber. We use Honda's brand of silicone spray on door seals, run channels, etc with no harmful effects.
Old Apr 30, 2012 | 08:29 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Do like the video posted above shows, remove seal and lay it out flat on the floor, I poured some soapy water thru the seal just for good measure, get your fish tape and push it through the seal. I used a zip tie to hold the tube on the end of my fish tape and dropped all the tubing into a bucket of soapy water and just pulled the tubing through the seal. The doors close firmly, and with the silicone tubing they close without having to slam and really cut out alot of road noise. It is by far one of my favorite low cost mods!!
trekbasso's Avatar
trekbasso
Thanks honeydew for the Amazon link. I will order later. Pretty funny looking at the "other things bought" with this tubing, a lot of truck stuff!!
Thanks to the OP for bringing this up.
Old Apr 30, 2012 | 09:55 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Adjusting the door latch post so the door closes tighter works to cut down on wind noise. That's what I did on the one door that had a wind noise problem. They are adjustable for a reason.
DND58's Avatar
DND58
This is the tubing I picked up from Amazon. I have not started, and hope the tube is not multiple pieces requiring splices.
Amazon.com: Latex Rubber Surgical Tubing - 1/4" I.D., 3/8" O.D., 1/16" WALL - 39323932 38: Health & Personal Care
Costa, just soapy water and tube pulled in easy?
Also feels like solid foam in weatherstrip near where front door/back door meet on my supercab. How are you guys handling this? Cut a slot and remove?
Thanks
Old Apr 30, 2012 | 09:59 AM
  #28
MisterCMK's Avatar
MisterCMK
I did the passenger and driver door on my F-250 and the passenger door closed fine after the tubing. The driver door was very hard to close and I still had a wind leak. I pulled the tubing out and then it closed nicely again. A while later I was driving down the road and happened to put my finger in the corner of the window and the wind noise stopped. The noise was actually coming from the door glass run/channel. I replaced that and the noise stopped. I think the part was around $80 and pretty easy to install.
The new part has foam and is stiffer in that spot than the old one.
Old Apr 30, 2012 | 10:47 AM
  #29
nookiemonster55
2002 Ford F350 Super Duty - 13245155 Door opening weatherstrips
looking at this price list...about 45.00 PER DOOR!!
Old Apr 30, 2012 | 11:09 AM
  #30
MisterCMK's Avatar
MisterCMK
8C3Z-2521597-A
That is the part number for what I replaced.
