Throttle Cable on 1904
Old Jun 25, 2016 | 06:51 AM
jvmcc's Avatar
jvmcc
I've got a 53 f100 with 215 and 1904 carb. It has never had a throttle cable that is operated from the dash for as long as I have had it. I have the hole in the dash for it, but I see no place on the carburetor to attach it, if I bought one. The only place that I see for any cable is the choke (which I have always had.) Where does the throttle cable attach? Maybe my carb has a linkage for a car and not a truck? I am also a bit puzzled as to how a cable connection would permit free movement of the linkage from the pedal. I do not see anything in the Shop Manual that answers my questions.
Old Jun 25, 2016 | 07:46 AM
52 USCG Panel's Avatar
52 USCG Panel
My 1904 carb is on a 52, and my throttle is not working at the moment; but I believe it could. Here is what it looks like:
My cable is "frozen" and needs some sort of stop to allow the wire inside to move independently of the cable itself.
Old Jun 25, 2016 | 07:58 AM
bhalemail's Avatar
bhalemail
Your missing the cable holder in second hole. I'll post a picture of mine
Old Jun 25, 2016 | 08:03 AM
52 USCG Panel
Thinking some more about my throttle arrangement--I believe the bigger lever that the cable attaches to should be positioned ahead of the other smaller lever in the picture. I would think the bigger lever with the cable needs to pull back on the smaller lever for the throttle to open independently of the foot feed.
Old Jun 25, 2016 | 08:12 AM
bhalemail's Avatar
bhalemail
Hope this pic helps. Shows the throttle cable hooked to the cable holder on the manifold and "ready" to pull the arm back against the lower arm to set the hand throttle. The lower arm is hard to see. It's the white dot half way down the arm that will grab it when the cable is pulled.
Old Jun 25, 2016 | 08:28 AM
abe's Avatar
abe
The hand throttle on your 53 F100 would not have been stock. If your truck had one it would have been an option or special order. All trucks had the holes in the dash but those without it should have a chrome or shiny plug in the hole. Do you have a cigar lighter? If not then you should have a plug in that hole. If you do not want the hand throttle, Mid Fifty and others sell those hole plugs.
Old Jun 25, 2016 | 08:29 AM
52 USCG Panel
Thanks! I see now what I'm missing.
Old Jun 25, 2016 | 09:01 AM
CBeav's Avatar
CBeav
Since I have a recirc' heater and saw no practical use for a throttle (for me) I plan on installing a heater valve and use a heater cable/switch from an Econoline in the throttle hole. Heater Switch and Cable | Dennis Carpenter Ford Restoration Parts and bezel Heater Control Bezel On Dash | Dennis Carpenter Ford Restoration Parts I realize the bezel doesn't match but I can live with that and not having a bracket dangling under the dash.
Old Jun 25, 2016 | 09:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B6T-9775-A (replaced FAB-9775-C) .. Carburetor Throttle Control [Cable] / Obsolete
NORTZ & VIRKLER FORD in Lowville NY has 1 = 315-376-6594.
Pic: See 9775 (at bottom of page) for applications: W & WH are F500/600 COE's / TH is an F600 conventional cab / THQ is a F700.
Old Jun 25, 2016 | 10:02 AM
NumberDummy
Originally Posted by CBeav
Since I have a recirc' heater and saw no practical use for a throttle (for me)...
I plan on installing a heater valve and use a heater cable/switch from an Econoline (Not!) in the throttle hole.
Be aware of what you're buying!
This heater switch & cable is C7TZ-18578-A = 1967/77 Bronco / The bezel is C5UZ-18598-A = 1965/67 Econoline with auxiliary heater.
The cable controlled heater water valve (not noted) is C3UZ-18495-A (Motorcraft YG-133) / Available from Ford.
Applications: 1963/67 Econoline / 1965/72 F100/350 with Fresh Air Heater / 1966/77 Bronco.
Old Jun 25, 2016 | 10:30 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Bill - what is the number for the bracket in bhalemail's pic? I don't find it in any of my Chassis Catalogs, and need it too. Thx. Stu
Edit - is it 2C 9764-A? Bracket Assy, Carb Throttle Control? I find that listing but no picture yet. Stu
Old Jun 25, 2016 | 12:12 PM
jvmcc's Avatar
jvmcc
Thank you for this photo. I do not have these linkage pieces, and as Abe says, they didn't come with these trucks, so I never did. I have never missed not having a throttle **** or cable. I never had, as far as I can tell, a cigarette lighter either. It looks like I need two of the plugs for the dash. I have been considering using the cigarette lighter hole for a USB port if and when I do something about a sound system.
Old Jun 25, 2016 | 12:49 PM
truckdog62563
The 2C 9764-A is in the paper catalogs and listed for all 215/223 applications but not pictured that I can find. Parts Voice shows Green Sales has it so I'll call them Monday to order one and see if that's it. Stu
Old Jun 25, 2016 | 01:25 PM
NumberDummy
2C-9764-A .. Bracket Assy. - Carb Throttle Control - 215/223 I-6's / Obsolete
I cannot find a pic, either.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
You could ask Green to take a pic, then email it to you.
Old Jun 25, 2016 | 01:38 PM
truckdog62563
Okay, good. You can't find the pic either. I'm not crazy. Will call them Monday. Thx. Stu
