Taking off the accelerator cable
Old Aug 29, 2006 | 05:17 PM
eigenvector's Avatar
eigenvector
I want to clean out my throttle body, gently no harsh chemicals, as well as inspect the EGR ports. But to do this I have to take off the throttle plate, but to do this I have to take off the cable for the accelerator.
If I remove the bolts holding the throttle plate on, will I get smacked in the forehead by the accelerator cable or is the cable not under tension?
This is for a 3.0 FFV.
Old Aug 29, 2006 | 08:42 PM
RangerPilot's Avatar
RangerPilot
You have to take off the cable? You sure?
You won't get smacked though, there's no tension in the cable at idle other than the slight tension from it being bent into shape, nothing that's gonna smack you in the face.
Old Aug 29, 2006 | 09:29 PM
eigenvector
That's good to know. I didn't want to fiddle with the accelerator cable without at least asking first. I figure I can just take the 4 bolts off the throttle assembly and not mess with the accelerator cable assembly. It should come off in one piece.
xtmsports
Nov 8, 2024 10:57 AM
rg200amp
Modular V10 (6.8l)
Mar 28, 2008 12:27 AM
runner
13
Oct 6, 2006 04:15 PM
yosemite
1978 - 1996 Big Bronco
Dec 21, 2002 06:32 PM
