Fuel level sender
Old Apr 30, 2012 | 11:25 AM
  #61
lavatan's Avatar
lavatan
Originally Posted by Archion
If you do that, remember to grab the pigtail for the sender, it'll be different.
19 gallon Aftermarket #'s
Tank 80-84 = F6A
Sender 73-84(?) = FG74A
You should be able to find these at a decent price locally.
Yeah, I noticed that they are different. If it is the single tube version it should have only 2 prongs if I'm thinking correctly but the connector could be much different.
Old Apr 30, 2012 | 12:14 PM
  #62
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Jeremy, my 86 is Canadian built, according to what the dealer told me when I bought it in 1994, all crewcabs at that time were built in Windsor Ontario. Guy I used to work with thought it was funny, his Nissan was built in TN, and my Ford was an "import".
Old Apr 30, 2012 | 01:13 PM
  #63
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Windsor? Look at the 11th digit of your trucks VIN for the assembly plant code. I'll betcha it's a C if your truck was assembled in Canada
C = All 1968/79 Crew Cabs were assembled at the Oakville Ontario Truck Assembly Plant, so the the same thing holds true through at least 1989.
Old Apr 30, 2012 | 01:35 PM
  #64
lavatan's Avatar
lavatan
I don't mean to contradict you Bill, but Ontario is in Canada.
Old Apr 30, 2012 | 02:42 PM
  #65
Archion's Avatar
Archion
Veteran: Marine Corps
Oakville was the truck plant in Ontario. Windsor, Ontario was the engine plant...
Old Apr 30, 2012 | 04:31 PM
  #66
NumberDummy
No **** Sherlock, that's what I just said. I've driven past the place. so I know where it is. Today the plant assembles Edge's, Flex's and the rebadged Lincoln versions.
There's also Ontario CA, where FoMoCo has a parts depot center.
Old Apr 30, 2012 | 05:39 PM
  #67
ctubutis's Avatar
ctubutis
Ah, NumberDummy... Always one to be kind & gentle & tender...... perhaps to his 5 howling basset hounds?
Old May 1, 2012 | 11:22 AM
  #68
NumberDummy
Where did I say Oakville Ontario wasn't in Canada? The whole gist of the post was that Windsor, Ontario Canada wasn't here 85lebaron2's truck was assembled, but in Oakville, Ontario Canada.
Some peeps cannot see the forest thru the trees.
caravaggio2000
Sep 17, 2018 04:48 PM
Brickster68
87
May 11, 2017 10:57 AM
Torsten.H
21
Nov 30, 2015 02:57 PM
89nolaf250
13
Dec 3, 2012 11:41 PM
Bigwrm
Feb 15, 2011 10:28 PM
