Fuel level sender
Old Apr 27, 2012 | 11:16 PM
lavatan's Avatar
lavatan
Fuel level sender
I finally got around to dropping the rear tank on my truck. I got the sender out and was looking on Rock Auto to purchase a new one. Now, the one on rock auto looks like this:
Mine however looks like this:
I wasn't able to find any part numbers on the old sender. I was able to find something similar from Spectra Premium with a part number FG74A.
I guess what I want to know is, would this part work (upon closer inspection I think not) and what part will replace this? I thought the hard part was done when I got the tank dropped. Thanks for any and all help.
Old Apr 28, 2012 | 08:04 AM
Franklin2's Avatar
Franklin2
The one from rockauto is the proper one for 99% of the trucks out there with 460 engines, since most all had electric fuel pumps inside the tanks. If you look at the one from rockauto, it has wires and a spot for the electric pump to mount, and it also had two fuel line outlets, one is the supply and one is the return.
The one you pulled out of your tank is a conventional unit for a carbed 300/302/351w. Single line, and only the sending unit wiring. If you think someone has converted your truck over, you can guess they may have swapped the tank or the sending unit around, and a conventional sending unit may work.
Old Apr 28, 2012 | 10:38 AM
ctubutis's Avatar
ctubutis
My experience with those Spectra Premium things hasn't been real good, they don't seem to remain working right for more than about 3 years. I figure on using OEM replacements from hereon out if I can find them.
To try and look up an OEM replacement for your truck, I would need the year, engine, what is the diameter of the hole in the tank, I think that's it. I can see you don't have an electric, in-tank pump which would mean you have a mechanical pump on the side of the engine.
Franklin is right, the one from Rock has accommodations for an electric fuel pump and you don't have the mating electrical connection for that.
Old Apr 28, 2012 | 12:49 PM
lavatan's Avatar
lavatan
It's an '85 F350 with a 460. It has the mechanical pump on the side of the engine. I'll have to measure the orifice when I get home. Any other information you might need?
Old Apr 28, 2012 | 01:29 PM
Archion's Avatar
Archion
Veteran: Marine Corps
The electric one is for the hot fuel handeling package. Mechanical was the base 460.
Old Apr 28, 2012 | 05:48 PM
ctubutis's Avatar
ctubutis
One tank or two?
What is your wheelbase size? (Will say on the door-jamb label.)
It'd help if you could give me the numbers on your old one. Should be something like E5TA 9275-H or some such.
Old Apr 28, 2012 | 09:11 PM
lavatan's Avatar
lavatan
It has two tanks. I removed the rear. The orifice is 3.615". The sticker says the wheelbase is 168. The part number that I could find is E5TF-EA.
Old Apr 28, 2012 | 09:32 PM
Gary Lewis's Avatar
Gary Lewis
I don't find an '85 F350 midship tank with one tube/line for a 460. The closest I get is E5TZ 9275-JA, Section 90 Page 30, but it is dual lines. So, what am I missing?
Old Apr 28, 2012 | 10:35 PM
lavatan's Avatar
lavatan
I'm assuming both sending units will be the same for both tanks with the single outlet.
Old Apr 28, 2012 | 11:45 PM
lavatan's Avatar
lavatan
I think I found it on LMC truck's website. I've been a little slow on the uptake I guess. The only problem is they don't have a picture so I can't compare the new to the old... I'll order it and see I guess.
Old Apr 29, 2012 | 07:50 AM
Gary Lewis's Avatar
Gary Lewis
Good luck. Let us know how it fits. And, if it has a part #............
Old Apr 29, 2012 | 08:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You aren't missing anything, the OP's sender is not original to his truck.
There is no single line sender listed for 1985/86 F350 460 midship tank.
These senders usually have an ID number stamped on them, but I can't see any evidence of same. 'Course the sender is so filthy, one couldn't see a naked maiden, if she was stamped on it.
The truck is 27 years old, so a PO may have swapped the tank from any 1980/84 F100/350.
Edit: See post 16.
Old Apr 29, 2012 | 08:42 AM
Gary Lewis's Avatar
Gary Lewis
You aren't missing anything. The OP's sender is not original to his truck,
These senders usually have an ID number stamped on them, but I can't see any evidence of same. This may mean it's an autoparts store replacement, and the wrong one for the OP's applcation.
Thanks, Bill. I'm glad to know that since I've been trying to learn how to use the catalog, with growing success, but just couldn't find that one.
Old Apr 29, 2012 | 08:51 AM
NumberDummy
OP is gonna buy a miracle sender from LMC (I wouldn't buy anything from LMC, they have no clue, their catalogs are rife with errors).
So, if it's correct, it's a miracle!
Old Apr 29, 2012 | 09:01 AM
ctubutis's Avatar
ctubutis
I wasn't able to find one, either, but I paid closer attention to what he (lava) said:
Post #1: "I finally got around to dropping the rear tank on my truck."
That's odd, rear tank there, yet we're looking for a side tank.
Post #9: "I'm assuming both sending units will be the same for both tanks...."
Seems to me this is a Frankentruck.... I googled the ID numbers he posted, found *one* relevant hit:
1985 Ford F350 - 18879335 8 CYL. 5.8L (351 C.I.D.)-W-GAS -midship:
9275 Sender Assy - Fuel Tank (NOT AVAILABLE) **TZ-9275-C Use w/19 gal. aft axle tank - incl. (1) E1VZ 9417-B gasket - one tube - Stamped E5TF-EA, gas exc. 460-unleaded fuel, 1985/ 1986 ; Ford 350 Series
So, if that information is correct, it looks like lava is taking the sender from the rear tank and wanting to use it in the side. I don't expect that to work; while the rheostats are probably the same, the float levers are entirely different.
I have no idea what was originally installed in this truck but I'd guess something different is wanted now. I like Franklin's idea, see if a sending unit for a different engine can be made to work.
