Need help with diagnosing possible fuel problem
Old Mar 19, 2013 | 12:01 AM
  #31
Ianmattf100's Avatar
Ianmattf100
My problem is back after running fine with the new carter 4070 for several trips. right around 1/4 a tank the other day it died at 20 mph. That morning I had taken an hour trip each way through a canyon pass as well with no problems. cools off and runs for 5 min the slowly looses pressure and dies. What is it that this happens right at 1/4 tank of gas? Is the sending unit going bad or the sock in there messed up? I pulled the tank tonight and am having it boiled out tomorrow. Do I need to buy a new sending unit or what do I look for in the original one that its bad? If I still have the same problem after this I am going to totally loose it.
Old Mar 19, 2013 | 07:34 AM
  #32
rustywheel68's Avatar
rustywheel68
one thing at a time-
hold off on doing anything else until you have the tank cleaned.
mtrondson
Oct 14, 2017 10:40 PM
Brad_81Ford
Jan 15, 2012 10:21 AM
williamgrogan
May 31, 2011 12:41 PM
cardude59
May 12, 2011 01:00 PM
jonvanzanten
Sep 1, 2007 10:18 PM
