Replacement Water Pump
Old Jul 2, 2007 | 01:38 PM
dustinova's Avatar
dustinova
I noticed my water pump is starting to let some coolant weep out in certain areas, so I'm going to tear it out and replace all cooling components (water pump, hoses, t-stat). Any recommendations on what kind of water pump to get? Right now, I'm just planning on getting a new Cardone unit and some Goodyear hoses. Thanks.
Old Jul 2, 2007 | 06:44 PM
danlee's Avatar
danlee
Those are probably good choices for the WP and hoses, but get a Robertshaw 333-192 t-stat. Don't buy the Auto Store universal replacement t-stat.
Old Jul 3, 2007 | 12:54 AM
Matts72's Avatar
Matts72
As long as you get a New waterpump, not a remanufactured one, you will be okay...
Old Jul 3, 2007 | 09:08 AM
dustinova's Avatar
dustinova
Is there anywhere that I can get a Robertshaw T-Stat without ordering it online? I checked out Flowkooler's website, and it looks a little too shady for me.
Old Jul 3, 2007 | 06:50 PM
father/son's Avatar
father/son
also check and be sure its your pump thats weeping and not your timing cover plate/water pump backing (whatever the proper term may be)
Old Nov 17, 2007 | 11:43 PM
dirtydoug0070's Avatar
dirtydoug0070
what kind of sealant should I use on a new water pump?
Old Nov 18, 2007 | 06:56 AM
danlee's Avatar
danlee
Silicone, just use it sparingly.
Old Nov 18, 2007 | 10:16 AM
fatherdoug's Avatar
fatherdoug
Prestone also makes a 333-192 thermostat. I have ordered twice from Flowkooler with no problems. However, some of their applications charts are incorrect. Make sure you know the diameter of the thermostat that you pull out. One of their charts shows a much larger diameter thermostat for the 351/400 than will actually fit.
CourierYVR
Aerostar
Oct 14, 2013 07:43 PM
projectdagger
Mar 15, 2013 10:44 PM
Epd444
Apr 26, 2012 11:18 AM
marte'
May 20, 2006 07:46 AM
andym
Jul 8, 2005 11:52 AM
