100+ cc DB2...???
Old Jul 10, 2012 | 11:07 PM
  #211
RacinNdrummin's Avatar
RacinNdrummin
Im debating building an input shaft... I could build it myself and have it treated... But I dont know if its necessary... I also dont want to find out if it is, so im still on the fence. Ill have to make a decision soon I guess.
Old Jul 10, 2012 | 11:23 PM
  #212
typefour's Avatar
typefour
justin, where did your pin break? I dont think I ever asked.
Old Jul 10, 2012 | 11:52 PM
  #213
NMB2's Avatar
NMB2
In the neck down
Old Jul 11, 2012 | 03:45 PM
  #214
turtlemann14's Avatar
turtlemann14
if the input shaft breaks it won't damage anything will it? i mean there will be metal shards that will need to be cleaned out but other than that it should be fine other than a tear down.
if it where me i think i would make one and have it on hand encase the original bites the dust or if you deiced to bore it out more and try to get even more flow out of it.
Old Jul 11, 2012 | 05:12 PM
  #215
NMB2's Avatar
NMB2
Why would there be metal shards? If it breaks, it will be a clean twist off.
Old Jul 11, 2012 | 05:40 PM
  #216
turtlemann14
you don't think there will be any fragments? even dust size could be bad considering how hard the metal will be.
Old Jul 11, 2012 | 06:24 PM
  #217
NMB2's Avatar
NMB2
no........
Old Jul 11, 2012 | 06:54 PM
  #218
turtlemann14
ok well, i would still go ahead and make one lol
Old Jul 11, 2012 | 07:34 PM
  #219
NMB2's Avatar
NMB2
Then we can't find a shop to calibrate it.
The shafts will either break/twist on the bench or they wont. Its not something that is going to fatigue over time and break.
Old Jul 11, 2012 | 08:06 PM
  #220
turtlemann14
why would you have to calibrate it replacing the shaft? it only has one output on it doesn't it?
i would think that you would have to re cal it after replacing the barrel, not the input shaft
unless you have to pull it completely to put the shaft in?
Old Jul 11, 2012 | 08:09 PM
  #221
88 Ford IDI's Avatar
88 Ford IDI
Are you guys looking for someone local to you to do the calibration?
Old Jul 12, 2012 | 01:21 PM
  #222
Bonanza35's Avatar
Bonanza35
Looks great. Been following this tread. Hope all works out.
Chet
Old Jul 12, 2012 | 02:08 PM
  #223
NMB2's Avatar
NMB2
Top secret.
Old Jul 12, 2012 | 08:11 PM
  #224
Aune163rd's Avatar
Aune163rd
lol i like your thinking NMB2....except I have a top secret clearance, so spill the beans lol.
Old Jul 12, 2012 | 10:29 PM
  #225
NMB2's Avatar
NMB2
Need to know basis.....
