Slow Power Loss
Old Apr 21, 2012 | 04:50 PM
JOHN2001's Avatar
JOHN2001
Slow Power Loss
Ive had my truck for about 2 years now and have done all the stuff in my signature plus some. I put a set of 38s on it not long ago, I still have 3:73 gears so I know thats affecting a lot of power theres more to it Ill explain. When I bought my truck it had 36x14.5s on it and before I put the tuner on it would set me back in my seat just a little. When I put the tuner in WOW she went from what I expect an 8000 pound truck to do to the fastest full size truck Ive ever owned in 15 mins!!
Now to clear up what Ive been noticing over the past year, she doesnt get up and go much, I still make about 25 pounds of boost smokes in 80e until the turbo lights then it clears up. During the winter months I put on a set of 315/75r16 (34.5") snow tires which I took off not long ago so the feel of the truck with the power level and tire is still fresh in my mind. Something is weak shes a turd, because it feels like Im in my stock tune with my 36'' tires while Im really in my 80e tune with the 315/75 on it. At first I thought I was just getting used to the power... Until my wife asked me why the truck was such a dog.... Any ideas?? This is driving me crazy
Old Apr 21, 2012 | 05:57 PM
Tugly's Avatar
Tugly
250K miles and my HPOP is giving up... new one next weekend (if it arrives in time). My symptoms? Spunky in low RPM, but fizzles pretty quick. AE data confirmed HPOP is too pooped to pop.
Old Apr 21, 2012 | 06:03 PM
Bonanza35's Avatar
Bonanza35
You need to pull codes. You could have boost leaks also. If it feels stock, pull the tuner out and see how it feels. Should be even worst.
Chet
Old Apr 21, 2012 | 07:33 PM
JOHN2001's Avatar
JOHN2001
Tugly I just rolled 114K, but the symptoms seem to be the same.
Ive always made 25-27 psi boost at WOT so I dont have a boost leak. I did set the tuner to "stock" and yeah... I felt like I needed to get out and help push her to get moving.
I dont have AE or know anyone who does and I cant afford to bite the bullet yet, lets say it is the HPOP going out will it hurt anything at all or just loss of power until I can get AE and fix it
Old Apr 21, 2012 | 09:49 PM
Tugly's Avatar
Tugly
IF it is the HPOP, I haven't yet heard of one just up and dying... but I'm still a semi-newbie. I know there are many out there with weak HPOPs chugging along - myself included. Have you tried putting out the call for those in your area with AE? I helped someone the last time I was in the Seattle area.
Old Apr 21, 2012 | 10:42 PM
JOHN2001's Avatar
JOHN2001
yes I di d and score
Old Apr 21, 2012 | 10:48 PM
Firefighter 1406's Avatar
Firefighter 1406
I think it's those new wheels I can take care of that for you.
Seriously I can.
Hope you get it figured out.
Old Apr 22, 2012 | 05:53 AM
Tugly's Avatar
Tugly
Cool! You may already know this, but I'll post it anyway (these instructions are generic):
All sampling times at default 100 milliseconds works fine.
MPH- set max to 100
RPM - set max to 4000
Injector Control Pressure - set max to 4000
Injector Control Pressure Duty Cycle
Accelerator Position Sensor volts - set scale to 20
Fuel Injector Pulse Width - set scale to 10
Anything more than that will slow down the data sampling, anything less than that can't paint the whole HPOP picture. Find a desolate straight road in good weather (and with good tires) and stop. Make one stock run by burying your foot (make sure the floor mat isn't blocking anything) and run it up to something safe for you and let off. I usually get up to 80, that gets me enough data. I tried 90 once and that was overkill, so I feel warm and fuzzy about 80.
If you have a tuner, put on your biggest HP tune and do the same run again. It's important to remove variables in conditions, so using the same straight road (same incline/deline, if any) right after the stock run (same weather and fuel load) will give the most accurate information. Removing variables isn't critical for testing for a bad HPOP, but it really aids in getting a before/after profile if you do any repairs.
Old Apr 22, 2012 | 08:28 PM
JOHN2001's Avatar
JOHN2001
Thanks Tugly I dont know anything about AE at all. I hope Dan does. My highest setting... that 140 aggressive and I was advised not to drive in it, I just use it to blow smoke. Maybe Ill stick with the 120. Some times I wish you were my neighbor lol
Firefighter..... There all yours if you want them... Im not saying your going to like the price (I gotta make a profit) but there yours
Old Apr 22, 2012 | 09:00 PM
Firefighter 1406
Just had to give you a hard time. I will have a set one of these days
Agg2001
6.7L Power Stroke Diesel
17
Mar 24, 2014 09:58 PM
Noisyboy
Feb 2, 2013 01:32 PM
76'SuperCab
23
May 19, 2012 05:33 PM
1L243
Computer Chips & Tuners
Oct 8, 2011 08:56 AM
fordmustangfan67
Aug 3, 2009 06:29 PM
