6.0 help!!!!!!!!!!! oil problem
Old Apr 21, 2012 | 10:01 AM
cheezit's Avatar
cheezit
a cheep thing to try is the oil pressure regulator. often times they will jam up in the housing and stick after a high side pump failer. spring may look good but....
also there is a valve that the spring goes into.
just a thought.
Old Apr 21, 2012 | 04:17 PM
BLADE35's Avatar
BLADE35
Originally Posted by Special Ed
Pressure regulator spring?
just a thought.
This is what I would check to
In past reading the regulator looked good but the housing it sits in was coked with junk and would stick
Guy also reported he cleaned the LPOR housing and a little port within and issue was resolved
worth a Shot IMO
Old Apr 21, 2012 | 10:36 PM
jmyrkle's Avatar
jmyrkle
I will check the regulator again. Another guy suggested that maybe there was a problem with one of the cooling jets maybe to blame or a collapsing lifter. Any thoughts?
Old Apr 21, 2012 | 10:40 PM
bismic's Avatar
bismic
No way would I tear into the engine before at least trying a new LPOP regulator.
Old Apr 21, 2012 | 10:51 PM
jmyrkle's Avatar
jmyrkle
I am going to pick up the truck Monday. I will start with the regulator and post my results.
Old Apr 21, 2012 | 11:00 PM
bismic's Avatar
bismic
LPOP regulator bolt 3C3Z-6C751-A
LPOP regulator o-ring W302722
Old Apr 22, 2012 | 09:12 AM
cheezit's Avatar
cheezit
a j-jet will not casue a lifter issue. j-jets cool pistons a failed one will give you a melted piston
critterf1
Jul 4, 2012 03:13 PM
jlt59912
Nov 6, 2011 11:53 AM
pintoches
Dec 3, 2010 02:47 PM
460f350
Dec 8, 2006 07:34 PM
RonF150
Mar 4, 2004 12:29 PM
