Oil Pressure
Old Nov 6, 2011 | 10:07 AM
jlt59912's Avatar
jlt59912
Oil Pressure
I just bought a 1988 F-150 LWB, 306 and replaced the faulty 0il pressure sensor. Now when the truck is idling the oil pressure falls completely off. Any thoughts??
Old Nov 6, 2011 | 11:53 AM
76250_4x4's Avatar
76250_4x4
the stock gauge reads normal anytime the oil pressure is over 7 psi. so if its dropping at idle its going below 7 psi of pressure. probably a worn out engine would be the culprit. does the engine make any noises? it probably just needs new bearings and an oil pump to make it new again. if i were you i would go and pick up an aftermarket gauge for oil pressure, it will give a much more accurate reading
87f150stepside
Feb 13, 2010 08:21 PM
Joker50
Feb 19, 2008 10:35 AM
460f350
Dec 8, 2006 07:34 PM
Craze
Jul 30, 2004 04:04 AM
