suspension issues?
Old Apr 19, 2012 | 07:11 PM
cory5517's Avatar
cory5517
suspension issues?
Ok when my suspension articulates on uneven surfaces I get a loud popping sound from the front and rear of vehicle. I'm also feeling like somethings hitting the floorboards when I hit a bump. Anybody had this issue and what did you do to fix it?
Old Apr 20, 2012 | 03:11 PM
Layson's Avatar
Layson
Never heard of that one before. You ever get under the truck and just look everything over?
Old Apr 20, 2012 | 03:19 PM
CampSpringsJohn's Avatar
CampSpringsJohn
What you probably have are worn out bushing in the sway bars, or the spring bolts are popping from the extra flexing from the springs. Look for some rust rings around the spring bolts, and check your bushings on your sway bar. My 1st guess is it's the spring bolts.
Old Apr 20, 2012 | 03:28 PM
429 f-100's Avatar
429 f-100
check balljoints another good place for noise
Old Apr 20, 2012 | 04:16 PM
1WildPig's Avatar
1WildPig
I had to replace my swing arm and frame link bushings to fix the "knocking" on the floorboard...used Energy Suspension parts ...
Old Apr 20, 2012 | 04:30 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Sway bar links or ball joints. Been there done that....to both.
Old Apr 20, 2012 | 04:51 PM
cory5517's Avatar
cory5517
I've been under the truck and tugged on stuff and can't trace where the noise is coming from.
Old Apr 20, 2012 | 05:32 PM
cory5517's Avatar
cory5517
Other than its coming from the front and rear
jw4hd
Jan 24, 2012 10:49 PM
AK-Excursion
Mar 22, 2008 05:05 PM
Flobber
Mar 17, 2008 02:53 PM
Chopper_WSP
Apr 7, 2007 07:45 PM
Menudo
Offroad & 4x4
Sep 5, 2003 12:10 AM
