Sponsored by: Real Truck
Suspension sqeaking
Old Mar 25, 2007 | 08:45 AM
Chopper_WSP's Avatar
Chopper_WSP
Suspension sqeaking
Hi to all, its been a while since I've posted, so I'm not sure if I'm posting in the right place....But I have a 04 S.D. 4x4 with the V-10. I have a sqeak comming from the driver side rear bushing in the leaf spring, any clues on how to fix this? I still have an extended service plan, but thats $100 every time I take it in...Any help would be great. Thanks, Chopper.
Old Mar 25, 2007 | 08:56 AM
hydro_37's Avatar
hydro_37
Could be the sway bar, drag link or other front end bushings too. Try spraying each different one with WD-40 till you find the one that squeaks and then replace it. Best thing is to replace them anyway depending on mileage. I kept spraying mine till I had time to replace them. I drove it like this for almost a year.
Old Mar 25, 2007 | 09:07 AM
Chopper_WSP
Yeah, I've replaced pretty much traced down to the bushing in the leaf spring, if I lay under the truck and push up on the frame it squeak in the bushing that connects the spring to the shackle. I will try to get some WD-40 in there and see if that helps...Thanks, Chopper.
Old Mar 25, 2007 | 09:10 AM
Chopper_WSP
Opps! I ment I replaced the sway bar, end links, ect... then traced it down to leaf spring bushing 1 trip to the sand dunes pretty much wipe out my front suspension (
Old Mar 25, 2007 | 10:24 AM
twayneb's Avatar
twayneb
I find silicone spray works best. The WD40 tends to attract dirt and grit.
Old Mar 25, 2007 | 11:09 AM
Super08's Avatar
Super08
Something else to check is the parking brake cable. Mine squeaked like crazy on my 05 untill I finally figured out what it was. It would rub up and down on the wire hoop it goes through on the side of the frame just ahead of the rear left wheel. Just put a little lube on it and all was solved. Drove me nuts untill I found the source.
Old Apr 5, 2007 | 06:40 PM
boxcar1974's Avatar
boxcar1974
I have the same squeek.. WD-40 lasts 2 days, silicone sprays last 2 days, dry graphite last 2 days, and low and behold PB Plaster last about 2 months. PB Blaster states restores life to o-rings so I figured it was safe to use on the rubber bushing.
My squeek is from the rear bushing on the passanger front leaf spring.
Old Apr 5, 2007 | 09:48 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Unless you put a lift on and they used polyurethane bushings for the springs, that squeek is because the rubber has seperated from the metal inner bushing, so the bushing is free to turn in the rubber.
It's only a matter of time before it wears out, it's not supposed to rub, the rubber is supposed to stretch and come back.
That is, IF it's really the leaf-spring bushing. With polyurethane bushings, the inner bushing is supposed to rotate freely. Which is why they sometimes squeek
WD40 is not a lubricant. It displaces water. It happens to contain things that make it slippery, but it's really not meant for that. Silicone is better all around. PB Blaster? Never used it, but if it says it helps rubber o-rings, it can't be all bad.
Old Apr 6, 2007 | 02:44 PM
hydro_37's Avatar
hydro_37
Great post boxcar. I will be trying that next time I get a squeak.
Old Apr 6, 2007 | 05:48 PM
boxcar1974's Avatar
boxcar1974
Yeah. PB Blaster is great stuff. It states the O-ring along with restores life to rubber seals. Heck I even used in it in a corroded rear plate light bulb. The bulb was burned out and the socket was all fuzzy. Cleaned it with baking soda and the new bulb was having a hart time staying lit. Cleaned it again and coated it with PB Blaster and perfect.
So a couple times a year, usually at the oil change, and I just spray the leaf spring bushings and all is quiet.
Old Apr 6, 2007 | 05:55 PM
countrycar's Avatar
countrycar
Hey Chopper, I've dealt with this myself ,evertime it rains then dries up it seems i'm underneath the truck spraying wd, silicone etc. Well I finally fixed it. I got underneath and jacked the truck up high enough to take the pressure off of the bolts. First crack the nuts acouple of turns then begin to lift the truck. You will need an 3/4 impact wrench or a very strong 1/2, to loosen the nuts and back the bolt with a wrench. Once you do this remove the nut and drive the bolt back with a punch just far enough to expose the shoulder of the bolt. DONOT REMOVE THE BOLT COMPLETELY!!! Leave the threads in and Donot grease the threads. When you're done aplying the grease, use the punch to re-aling the springs as you tap the bolt back in to position. If you get greast on the threads be sure to remove the grease completely with carb cleaner or some other type of solvent before you put the nut back on so that they don't come lose. I did this on my truck a year ago and it has'nt squeed since. Oh be sure to recheck and tighten the nuts agian about 500 miles or a month and agian at 1,500 miles or 2-3 months. Just to be sure. I hope this helps you Take Care.
Old Apr 7, 2007 | 07:45 PM
Chopper_WSP
I will try that, thank you all for your help, Chopper.
GOHLS
6.4L Power Stroke Diesel
Mar 19, 2012 09:34 PM
bass-n-fire
Feb 10, 2011 11:25 PM
khadma
Aug 6, 2006 06:32 PM
1990350
Jun 10, 2002 09:42 PM
chopper
Feb 14, 2001 07:28 PM
