Clutch Problems.....Still!
Old Apr 22, 2012 | 07:14 PM
  #91
1951flatheaddave's Avatar
1951flatheaddave
Its all covered, so I have an 11" PP and a 10" disc.
I will road test it when my new carb comes in. The new one from advance leaks gas pretty bad so I dont feel comfortable driving it. New one will be in Friday.
Old May 25, 2012 | 01:36 PM
  #92
1951flatheaddave
4tl8ford,
Took the truck out for the first time yesterday and that transmission you gave me works like a dream! The 10" clutch disc and 11" Pressure plate works good. No more grinding and no more clutch disc getting jammed into the flywheel. My clutch rod clevis is still adjusted WAY in, like so far that the threaded rod stiocks through the clevis almost rubs the "Z" bar but it seems to engage and disengage ok.
As far as my eyeball front end alignment, I need new eyes. It was VERY sketchy and is now at the alignment shop.
Thanks for all your help, all of you!
Old May 25, 2012 | 03:23 PM
  #93
4tl8ford's Avatar
4tl8ford
Glad to be able to help you get on the road - We need more old Fords adding to the scenery
Old May 25, 2012 | 06:12 PM
  #94
ALBUQ F-1's Avatar
ALBUQ F-1
How about some pics?! or a video?
Old May 25, 2012 | 07:19 PM
  #95
1951flatheaddave
Ross, Ill get some tomorrow. I think the sun is supposed to shine down all day so I will get the truck all cleaned up and shining.
P.S. Alignment is all adjusted and the truck drives much much better!
Old May 25, 2012 | 09:38 PM
  #96
underthebridgejim's Avatar
underthebridgejim
FTE fan
Man, you have used up your lifetime alotment of frustration on this one. Congrats on not giving up. Im glad your back up and running.
Old May 26, 2012 | 06:18 AM
  #97
1951flatheaddave
Jimmy, you better believe it! It was get 1 thing fixed and then find 2 more things wrong. I need to learn to leave things alone if they arent broken instead of just tearing everything apart just to figure out how it works. As soon as you do that you have a whole new can of worms to deal with.
r_reed
Jul 23, 2013 09:27 PM
tiredolbiker
18
Dec 20, 2012 06:53 PM
Zoomie331r
Sep 24, 2004 08:50 AM
hster
Sep 1, 2004 12:34 AM
CALJJ
Nov 27, 2002 10:49 PM
