Clutch Problems.....Still!
Old Apr 16, 2012 | 07:02 AM
  #46
1951flatheaddave's Avatar
1951flatheaddave
Old Ugly, Fantastic Idea! I have different thicknesses of metal floating around my garage. I can put a few pieces around the trans in different places as shims in a sense. I will start out thin and go thicker until the clutch disc can spin freely.
Dick, I will file that input shaft a bit just to have peace of mind it is sliding all the way in either direction.
All great ideas, thanks again!
I have another clutch on order, this time from advance. I am going to try and contact the guy I gave my old one too just for some reference too.
Old Apr 16, 2012 | 11:32 AM
  #47
4tl8ford's Avatar
4tl8ford
Pictures of the 10" clutch from Dick's old 1948 F1 Fprd Panel Truck
1948 Ford F1 10" clutch thickness
1948 Ford F1 10" clutch and throw out/release bearing clutch side
1948 Ford F1 10" clutch and throw out/release bearing Transmission side
1948 Ford F1 10" clutch flywheel side
Square across Ford F1 clutch rivits and surface
Da F2
Old Apr 16, 2012 | 11:50 AM
  #48
ALBUQ F-1's Avatar
ALBUQ F-1
Dick, what is the total length of the splined hub?
Old Apr 16, 2012 | 11:58 AM
  #49
4tl8ford's Avatar
4tl8ford
Here's the story - After I took the above pics I moved a ton of crap to get to a F1 LD 3 spd trans - Being the type that I can be I intended to take sone pics of the clutch disk on the trans input shaft - It has some rust - The disk is now stuck - Taa Daa - Nothing else is going to happen today - I mowed the lawn and helped a neighbor and my back is killing me.
  #50
1951flatheaddave
Dick, is this the clutch from the panel? My throwout bearing/ hub assemble looks nothing like the one in your pictures.
Im curious to know too, how thick is that clutch hub total, and just on the transmission side?
Old Apr 16, 2012 | 12:01 PM
  #51
4tl8ford's Avatar
4tl8ford
Disk, throw out bearing and pressure are from my 1948 Ford f1 Panel that you have the tranny from
Old Apr 16, 2012 | 12:03 PM
  #52
1951flatheaddave
Does the clutch disc hub look the same on both sides of the disc, as far as length go. Mine is a good bit longer on the transmission side, much shorter on the flywheel side. If yours is the same on both sides or close to the same that may be my issue
Old Apr 16, 2012 | 12:10 PM
  #53
4tl8ford's Avatar
4tl8ford
Trans side is longer - Every thing else looks the same except for those big *** rivets that you have
Old Apr 16, 2012 | 12:34 PM
  #54
1951flatheaddave
Hahahahaha thanks for checking. I am stumped!
Old Apr 16, 2012 | 01:41 PM
  #55
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 1951flatheaddave
...My throwout bearing/ hub assemble looks nothing like the one in your pictures.
Can you send me a pic of yours?
Old Apr 16, 2012 | 02:01 PM
  #56
4tl8ford's Avatar
4tl8ford
From the deep recesses of the mind - You have an 11 in clutch (?)
There is a possibility of interference between the pressure plate and the clutch cover/front half of the bellhousing - The 11 in clutch wasn't used in all trucks between 48 and 52 - There is a bell going off that says that there were slight changes to the cover mid streme in production (Portions of the inside of the cover ground near the outside edges?
Oh And has anyone seen my horse I think I may have left it here earlier today
Old Apr 16, 2012 | 02:02 PM
  #57
1951flatheaddave
Just talked to Gary at Dennis Carpenter, hell of a guy I must say
Here is what we found:
All measurements are crude and done with tape measure but you get the idea
10" Clutch Disc
Transmission side hub length-7/16"
Flywheel side hub length-1/4"
Overall splined hub length-1.25"
11" Clutch Disc
Transmission side hub length-3/4"
Flywheel side hub length- 1/2"
Overall splined hub length-1.375"
It seems as if I have to run the 10" clutch
My old column shifted 3spd was the 11" clutch but maybe there is more of a spline cut into that trans compared to the floor shifted 3 speed input shaft
Do you guys think the 10" clutch will solve my problems?
P.S. if you remember way back I was having all of that trouble with the clutch linkage not hooking up right to my new trans, this is probably why!
Old Apr 16, 2012 | 02:05 PM
  #58
1951flatheaddave
You are right Dick, 11" clutch and I did have interference with the pressure plate rubbing on that adapter piece. I had to grind clearance into that ring, it locked the motor up when I tried to turn it over
Old Apr 16, 2012 | 02:06 PM
  #59
tinman52's Avatar
tinman52
Welder User
I just looked at some old 11" disks that I have.......on the flywheel side, NO PART of the hub sticks up past the friction surface! I think you may have the wrong disk or a poorly made one.
Do you have the old one to compare it to?
I will try to get some pics, measurements today.....
Old Apr 16, 2012 | 02:12 PM
  #60
1951flatheaddave
Tinman,
I gave it to a guy that needed it. I had a new one and didnt think to save the old one. I am trying to get ahold of him to see if he still has it so I could comapre it. Thanks!
