starter problem
Old Apr 15, 2012 | 08:00 PM
ctubutis's Avatar
ctubutis
Bang on the solenoid and see if it stops turning. I'm thinking this solenoid is defective right out of the box....
When you had the starter tested, did they do a current draw on it? Or, did they just see if it spins?
Old Apr 15, 2012 | 08:01 PM
brokentv's Avatar
brokentv
One other thing I was thinking is I just recently got a new clutch and flywheel put in. Would by any chance a new flywheel cause more drag then an old one causing the starter to stress.
Old Apr 15, 2012 | 08:11 PM
brokentv's Avatar
brokentv
I'll try that it was the cheapest one they had, 10 dollars.
I believe they just checked if it spins.
Old Apr 15, 2012 | 08:29 PM
ctubutis's Avatar
ctubutis
If you can get the thing started & running, take it to Sears or Walmart or even a full-service gas station, they can do a starter draw test for you. This is the kind of test that's generally offered for free as a courtesy.
Parts store should also be able to do it but you apparently need somebody with a clue, sounds like you didn't run across such a person.
It's good that it spins, but it shouldn't be burning up your electrical system.
Need to get a decent solenoid, too.
Old Apr 16, 2012 | 07:39 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Your replacement solenoid was probably made in China, they are complete junk, unfortunately, with the possible exception of Motorcraft, all of them are crap. If I had seen this thread sooner I would have recommended you PM Archion for a PN for a PMGR starter for your application. They only use the fender mounted relay to engage a starter mounted solenoid that then engages the drive. If you don't have enough posts to PM, put something on here, and one of us will direct him to the thread.
Old Apr 16, 2012 | 01:23 PM
brokentv's Avatar
brokentv
So I ended up buying a new re manufactured starter, put it in and the truck started right up no problem. Hopefully the problem was just an old worn out starter.
Old Apr 16, 2012 | 01:29 PM
82f100460's Avatar
82f100460
Excellent!!!
anied52
18
Jul 22, 2016 04:56 PM
Stonesetter1
May 29, 2015 02:31 PM
mOROTBREATH
18
Sep 24, 2013 07:01 PM
bigdogchris
1978 - 1996 Big Bronco
Apr 28, 2012 07:21 PM
17fordguy
13
Oct 10, 2007 04:16 PM
