1978 - 1996 Big Bronco
starting issues
Old Apr 28, 2012 | 12:08 PM
bigdogchris's Avatar
bigdogchris
starting issues
i have a 1990 Ford Bronco. I think the starter might be bad...anyone know how i can check to see if starter is bad?
Old Apr 28, 2012 | 01:23 PM
Bubba Jones's Avatar
Bubba Jones
Starters typically last a pretty long time so it probably is a bad/corroded connection somewhere. I would check the connections on the starter, the solenoid and the battery before looking too much into the starter itself.
What are the symptoms? Do you hear a clicking? Starter acting slow? Starter not turning at all?
If you have a strong battery and the headlights/accessories work well, but the starter won't turn or turns very slowly, it could be your starter. I know it sounds funny but you could also try having someone hit the starter with a rubber mallet while turning they key and see if it starts. If that does work your starter is probably going bad then.
You could also try to bypass your solenoid by taking a screwdriver (make sure its insulated!!) and touching both terminals of the starter with the metal part. If your starter engages then you might have a bad solenoid or connection. If you do decide to do this make sure you are in neutral and aren't touching any metal part of the screwdriver!
Old Apr 28, 2012 | 01:36 PM
bigdogchris
thanks bubba, it is the starter...took it to a parts store and they tested it....and its broken
Old Apr 28, 2012 | 07:21 PM
Bubba Jones
Oh well that's a bummer. At least its an easy fix and I don't think starters are too terribly expensive.
mOROTBREATH
18
Sep 24, 2013 07:01 PM
brokentv
21
Apr 16, 2012 01:29 PM
guitarnik
Sep 2, 2008 08:04 AM
17fordguy
13
Oct 10, 2007 04:16 PM
Buggie
Feb 9, 2006 08:47 AM
