starter
Old Oct 9, 2007 | 06:44 PM
17fordguy's Avatar
17fordguy
starter
when i try to start the truck i can here the starter click but thats all it does is click realy loud. is this a bad starter or is there a temporary fix.
Old Oct 9, 2007 | 06:47 PM
MisterCMK's Avatar
MisterCMK
Check your battery voltage. A low battery will cause it to click. If your battery is fine then I would look at the solenoid on the starter and make sure that it is kicking out when you turn the key.
Old Oct 9, 2007 | 06:51 PM
17fordguy's Avatar
17fordguy
i know the bat is good its a newer interstate bat and i can hear the starter click loudly but it dont turn
Old Oct 9, 2007 | 07:01 PM
t4kne's Avatar
t4kne
Check the cable going to the starter too. The solenoid could be doing its job but the juice never gets to the starter motor.
Old Oct 9, 2007 | 07:05 PM
17fordguy's Avatar
17fordguy
ok thanks for the imput
Old Oct 9, 2007 | 07:22 PM
MisterCMK's Avatar
MisterCMK
Check your battery voltage. You can't tell the voltage just by looking at the battery.
Old Oct 9, 2007 | 08:55 PM
cowmilker's Avatar
cowmilker
Ya, make sure your cables are in good shape with no corrosion, and make sure the clamps are tight, and battery has a good charge (even though it may be a "good" battery it could be discharged). The click you here is telling that your soleniod is doing its job (usually).
If all is well with the battery and the connection, then I would hope it's your starter, because the other option is a seized engine.
Some of the "loud" click you hear could be the drive (bendix) kicking forward to enguage the flywheel, but the brushes (or other parts) inside are worn and there is no "turning", in that case the starter needs to be replaced or rebuilt (its cheaper sometimes).
Old Oct 9, 2007 | 09:00 PM
handsomerob's Avatar
handsomerob
There is a place up here that rebuilds starters and they do a great job and it's like $80 very good job. We had a starter rebuilt for our forklift and it works great.
Old Oct 9, 2007 | 09:04 PM
cowmilker's Avatar
cowmilker
One "temporary fix" is to bang on it with a hammer. But that is, in my oppinion, only one of those tricks that you pull when you are in the middle of no-where and there is a goblin after you. (it can and will cause damage if you hit it too hard, and it doesn't always work anyway). The last time I had a starter go out, I went to the parts store and bought a repair kit for it that cost about $13 (compared to a rebuilt one at $40 it saved me enough for lunch and a brick of .22 shells), just thought you might want to know about a little "cheaper" fix.
Old Oct 9, 2007 | 09:46 PM
stm250's Avatar
stm250
Mine did the same thing try jumping the solenoid w/ the key in run position thats how I had to start mine then I replaced the ign switch and actuator cam and also the solenoid then come to find out it was my nss so I didnt replace that I just rigged in a push button start for now. Let us know whats going on -Scot-
Old Oct 9, 2007 | 09:54 PM
17fordguy's Avatar
17fordguy
ok well i gotta get a ride to my truck in the mornin pretty bad when the fuel pump and starter both die on the same day pump was still under waranty but im to broke for the starter guess ill be push stasrting it.
Old Oct 9, 2007 | 10:35 PM
MisterCMK's Avatar
MisterCMK
Like I said, check your battery voltage. Also make sure that terminals are clean. Checking those won't cost you a dime.
Old Oct 10, 2007 | 02:28 PM
17fordguy's Avatar
17fordguy
well i ended up puttin it in neatral and crawlin under it with a wrench and jumpin the syloinoid
Old Oct 10, 2007 | 04:16 PM
flareside_thunder's Avatar
flareside_thunder
I didn't hear anyone say this soooooo check the NEGATIVE cables...usually that's what it is or your starter got hot got water on it and got lockedup.....
