Is it a clutch problem?
Old May 23, 2012 | 11:01 PM
  #106
BuckHammer's Avatar
BuckHammer
Yup. Just how mine is. I'm making this post before hearing your video, though, so standby for post-video reaction...
Edit made after viewing and hearing video: Yup. Just like mine.
Old May 23, 2012 | 11:12 PM
  #107
Teamrope's Avatar
Teamrope
I guess I can quit panicking now.
Old May 23, 2012 | 11:19 PM
  #108
BuckHammer's Avatar
BuckHammer
I was alarmed at first, also. It's just the nature of the beast, I believe. Worth it to not have to worry about a DMF coming apart, in my opinion.
Old May 23, 2012 | 11:44 PM
  #109
madpogue's Avatar
madpogue
It's also loud because you have it open. The boots on the shifter, esp. the white "inner" one, and the hard plastic bezel, make a BIG difference wrt. the noise level in the cab. Once you button it up, with the carpet in place, you'll hardly notice it.
Old May 24, 2012 | 01:51 AM
  #110
Talyn's Avatar
Talyn
Give it time, it goes away.
Why it goes away?
I have no idea.
Mines gone.
Old May 24, 2012 | 12:52 PM
  #111
strokin'_tatsch's Avatar
strokin'_tatsch
Why it goes away?
I have no idea.
Mines gone.
I was wondering that too. Mine started out extremely loud when I switched to the SMF, but eventually went away. I have a tiny bit of gear rollover now with the dual disc, but I have to be under the truck and right beside the trans to hear it. Not sure why it goes away after awhile.
Old May 24, 2012 | 02:20 PM
  #112
madpogue's Avatar
madpogue
Faded away on both ours after a while, too. Either that, or we all just get used to it...
Old May 24, 2012 | 03:45 PM
  #113
Talyn's Avatar
Talyn
If you listen close with mine, there is rollover still, but its so faint its not worth it.
But then some guys get no rollover at all.
I think its just an imbalance in the transmission. *shrugs*
Nobody really has a good explanation for it other than the fact the transmission is echoing the sound of the motor. But if that was the case, (haha... pun) it would never go away.
Old May 25, 2012 | 06:57 PM
  #114
Teamrope's Avatar
Teamrope
Well, got her all buttoned up and drove it to work today. I think the plastic bushing being removed from the end of the slave cylinder piston rod is bitting me in the butt.
With the clutch pushed in as far as I can possibly stand on it, the truck wants to move in 1st & reverse. Also, If I barely release the clutch it acts like it is fully released. Is there any way to adjust it?
Also still have an exhaust leak at the DP, but that I can fix.
Old May 25, 2012 | 07:06 PM
  #115
strokin'_tatsch
Did you check the fluid in the clutch master cylinder? It sounds like it's not bled. If you took the cap off so you could depress the slave cylinder, then that is indeed your problem most likely. If that plastic cap turns out to be your problem, than maybe that's what my problem is. I've never had this issue until I did my clutch this last time and during that time the plastic cap went MIA, so I don't have it now. Maybe that takes up just enough space to cause a problem, but I kinda doubt it.
Old May 25, 2012 | 08:51 PM
  #116
ReBilld's Avatar
ReBilld
I'm pretty sure the little plastic cap is missing from mine and I don't have this problem. I did when I bought the truck, when it still had the DM flywheel and old clutch. I tried bleeding it and that didn't help, so I put a master and slave from another truck I have on it and it's fine now.
Old May 26, 2012 | 02:29 AM
  #117
BuckHammer's Avatar
BuckHammer
I don't have the plastic cap and my truck doesn't do that. It shouldn't make a difference, or at least shouldn't produce that particular symptom.
Old May 26, 2012 | 07:17 AM
  #118
Talyn's Avatar
Talyn
The clutch rarely is right when you put it back together.
Sit in your truck and put the parking brake on and just stab the clutch pedal with your foot multiple times.
It will bleed the air out of itself.
I've noticed that sometimes when the slave moves all the way out it seems to get air in itself.
Old May 26, 2012 | 01:57 PM
  #119
Teamrope's Avatar
Teamrope
Thanks Tayln. I pumped the clutch a whole bunch of times and that seems to have worked.
Old May 26, 2012 | 02:02 PM
  #120
Talyn's Avatar
Talyn
It will take a bit. But it will come into it.
