Is it a clutch problem?
Old May 5, 2012 | 08:45 PM
nomad221's Avatar
nomad221
Performance Clutch - Ford PowerStroke
If okay with the mods. If not, delete.
My HD organic and flywheel is going in next week. YAHOOOO
Old May 5, 2012 | 09:58 PM
maverick1701's Avatar
maverick1701
Originally Posted by ReBilld
X2 on all of the above. I've got to get my DM out soon.
Im actually going back and forth with a guy over on OB about SMF/DMF...he claims DMF is better and the only pro of the SMF is cost.
Each one has its own pros/cons.
Old May 5, 2012 | 10:09 PM
Talyn's Avatar
Talyn
the DMF has 1 pro, vibration dampening.
Thats it.
Its a failure otherwise.
Old May 6, 2012 | 09:25 AM
ReBilld's Avatar
ReBilld
Originally Posted by Talyn
I got some pictures to upload to my DMF for dummies article.
I should do that. I'm feeling kinda lazy about it though.
Don't forget to tell him about the guide pins for the flywheel William! Great idea!
Old May 6, 2012 | 01:14 PM
maverick1701
Thats it.
I have been trying to tell the guy that....someone people just wont listen to reason
Old May 6, 2012 | 08:04 PM
Talyn's Avatar
Talyn
Opinions are like *******s, everyone has one.
if DMF was that great, all the companies would still be using them.
DMF's slip, and slip and slip.
Talyn's Avatar
Talyn
Then they fall apart or go kabloooie!
Old May 6, 2012 | 11:34 PM
BuckHammer's Avatar
BuckHammer
If I cared about reducing noise and vibration, I would drive a Camry.
Old May 7, 2012 | 09:29 AM
Talyn's Avatar
Talyn
you'd buy a rice burner?
Shun him!!
Old May 7, 2012 | 07:55 PM
ReBilld's Avatar
ReBilld
Old May 13, 2012 | 11:53 AM
Teamrope's Avatar
Teamrope
Got the package from Valair Friday. I went with the heavy duty organic. I don't tow much other than a M1 ft Monterey, but I do cut my own firewood.
I've got a Chiltons manual but it seems to cover a wide range of trucks, and for the transmission removal it does not list the steps for the transfer case. I've got the seats out and almost all of the inside the cab work done. I've got the shifters out, but all the stuff they bolt to is still in the truck. Any tips and pointers would be highly appreciated.
Old May 13, 2012 | 01:19 PM
Talyn's Avatar
Talyn
if you don't have a trans jack, use 2 floor jacks.
I built a part to go under the t-case to keep it from twisting. and use a 2x6 under the trans which I'll strap down to the trans to keep it from slipping.
Just pull parts and slide it down and back.
Be sure to take the bolt out of the 4x4 shifter. It will get caught on the floor pan.
Old May 13, 2012 | 01:51 PM
  #28
Teamrope's Avatar
Teamrope
I have a trans jack. I also have 2 floor jacks.
Should I keep the t-case and transmission together or separate them? Also wondering if I have to remove the piece that goes into the top of the trans.
Old May 13, 2012 | 03:29 PM
  #29
Talyn's Avatar
Talyn
Pull the shifter and the shifter tower.
Leave the T-Case attached.
When you pull the shift tower, be sure to pull strait up with it in neutral.
When the shift tower is out, look inside and there will be a piece of metal with a spring.
Note how it goes in, then pull it out carefully and set it on the dash.
Don't forget to put it back in when you re-assemble.
But you dont want it to fall down inside.
Then stuff a rag in the top of the trans.
This will make it easier to get the trans back if you dont have a lift.
I usually have to put something under my oil pan to keep the motor from moving so the trans will break loose from it.
6 bolts.
They are all easy when you know where they are at.
The biggest PITA in my opinion is taking the trans crossmember out.
I don't remember which size the wrench is.
You can do it by yourself, but its easier to have somebody hold the one wrench for you.
I usually pull the trans mount first, then pull the cross member.
Before you fuss with that, make sure you break the bolts loose on the trans to the motor.
Old May 13, 2012 | 05:44 PM
  #30
Teamrope's Avatar
Teamrope
I got the tower off by removing the 4 allan head screws. Shifter came strait up, but I'm not seeing anything with a spring on it that can come out. Didn't hear anything drop either.
I'm use to the starter having to come off on gas engines, but it looks like it doesn't on the Power stroke.
