Is it a clutch problem?
Old May 17, 2012 | 11:06 PM
  #76
ReBilld's Avatar
ReBilld
I'd just go ahead and do the 25 lbs. then.
Old May 17, 2012 | 11:07 PM
  #77
Teamrope's Avatar
Teamrope
Originally Posted by ReBilld
An extra set of hands is always helpful! I usually wind up doing it by myself and it can be rough. The last time I dropped out a trans and t-case still together, the thing rolled and pinned my hand between the jack and the stud sticking down out of the trans mount, almost pushed that stud right through the palm of my hand....OUCH! Ever since then I drop the t-case first and then the trans LOL! Good luck and I hope it all goes back together smooth! Let us know
Will do.
I've got 2 transmission jacks. ! under the trans, the other under the T-case. She's listing to port, but I think I can get a jack under that end and get her back up right..... At least I hope so.
I also noticed the plastic piece that slips over the ball on the end of the slave cylinder is brittle and cracked. I'm thinking it would be a good idea to stop at the stealership when I'm in town tomorrow and get a new one.
Old May 17, 2012 | 11:13 PM
  #78
ReBilld's Avatar
ReBilld
Yep, now would be the time to do it. I always try to button up all the little loose ends on things like that whenever I have everything torn down. No matter how little it is, if nothing else, it gives me piece of mind.
Old May 18, 2012 | 09:17 AM
  #79
Talyn's Avatar
Talyn
Guide pins on the trans make it super duuuuper easy actually.
If you have them.
Makes it easier to stab
Old May 18, 2012 | 11:07 AM
  #80
BuckHammer's Avatar
BuckHammer
Originally Posted by Teamrope
...I also noticed the plastic piece that slips over the ball on the end of the slave cylinder is brittle and cracked....
Lol, the dealership "ordered me one" and then it showed up and it was the wrong part. Then, they told me that part is only available with a new slave cylinder. Good luck, but I didn't have any when I tried.
If we're thinking of the same part, and if you can get one, order two.
Old May 18, 2012 | 02:45 PM
  #81
strokin'_tatsch's Avatar
strokin'_tatsch
That part should only be available with a new slave cylinder.
Old May 19, 2012 | 07:43 AM
  #82
Talyn's Avatar
Talyn
What plastic piece are ya'll talking about, I don't have one of those.
Old May 19, 2012 | 09:03 AM
  #83
richdawg's Avatar
richdawg
Does the piece look some thing like this?
Old May 19, 2012 | 11:12 AM
  #84
madpogue's Avatar
madpogue
They're probably talking about the little "cap" that comes on a new slave, goes over the end of the slave rod and clips to the slave body to keep the rod held back during shipping. You're supposed to keep it in place when you install the slave and unclip it from the slave body (or, let the clips break when you press the pedal the first time). Shop that did our clutch didn't put it back on when they put the truck back together.
Old May 19, 2012 | 12:13 PM
  #85
richdawg's Avatar
richdawg
madpogue: Thanks for that explanation, I was off track with my thinker.
Old May 20, 2012 | 10:36 PM
  #86
Teamrope's Avatar
Teamrope
She's bolted up and the cross member is back in place. Still have a lot of little things left to button up. Sounds like the piece is not needed then.
What is the secret to getting the slave cylinder back in place?
Old May 20, 2012 | 11:10 PM
  #87
jmpape's Avatar
jmpape
Seems like I pushed in and clipped it in the retract position with the white clip dealio. As I slid the slave into place, I pried a little on release lever and popped the ball end in to it's socket
Old May 20, 2012 | 11:11 PM
  #88
BuckHammer's Avatar
BuckHammer
The best way is to accidentally introduce a bunch of air into the system. That makes the slave much easier to compress. Ask me how I know.
Old May 20, 2012 | 11:18 PM
  #89
jmpape's Avatar
jmpape
I'm wanting to know?
I think bleeding that slave after it was mounted was the worst! Took me maybe an hour
Old May 20, 2012 | 11:57 PM
  #90
BuckHammer's Avatar
BuckHammer
I was being sarcastic. Sorry.
