Is it a clutch problem?
May 15, 2012 | 12:10 AM
I also pulled it as one unit using a trans jack. I loosened the exhaust at the down pipe from the turbo.
I had to do it twice now because of clutch problems.
It ain't easy, but you'll get it.
May 15, 2012 | 02:40 AM
Quote:
Originally Posted by
Teamrope
So far the bigest b!+$% has been the cross member. 2 bolts left on the passenger side upper mount to go.
I told you! =)
May 15, 2012 | 09:32 AM
while you have the trans out look at your up pipes and turbo mount real well make sure if there are any issues and major leaks you take care of it while the trans is out. Much easier.
May 15, 2012 | 11:42 AM
X2
I had a broken y pipe. Looked all over for one. Finally found one on eBay, $80. Those dang bolts are welded in seems like
May 15, 2012 | 12:53 PM
Talyn
Sorry.
I'm so used to having to take the whole tower off. (shift kit)
the part i'm talking about is under the part you pulled the shifter out of.
FYI, even though I have a shift kit, I don't have to pull it out to get the trans out. Still just have to pull the shifter.
May 15, 2012 | 04:46 PM
I installed my ZF with the shifter on it.
May 15, 2012 | 10:30 PM
BuckHammer
The whole shifter?
May 15, 2012 | 10:37 PM
I meant just the nub, obviously not the whole handle thing.
May 15, 2012 | 10:41 PM
BuckHammer
...I was wondering how high you had to jack the truck up to put it in with the shifter on it!...
May 16, 2012 | 01:39 AM
Got the trans, pressure plate & clutch out. Kind of pissed at Harbor freight.... Their deep well standard impact socket set is pretty much complete, but their metric is missing most of the sizes I need.... Namely 15 & 18 mm.
May 16, 2012 | 02:42 AM
I've seen a lot of sets that exclude the 18mm. But 15? That's just weird.
May 16, 2012 | 07:07 AM
ReBilld
That's funny right there!
May 16, 2012 | 08:30 AM
Yeah, 15 is a really really really common size.
Maybe you got a returned set.
He probably has like 2 19mm.s hah.
May 16, 2012 | 10:19 PM
OK.... Got transmission pulled, clutch removed and the 10 bolts that mount to the crank shaft. Darn DMF don't want to come off. Any suggestions?
Never mind... Got it.
May 16, 2012 | 10:21 PM
Talyn
No, the set don't have any doubles. It's made in China so I'm thinking it's a communist plot.
