2003 ranger
Old Apr 6, 2012 | 12:40 PM
nfg's Avatar
nfg
Question 2003 ranger
I lost the winshield wipers, speedometer, dome light, door alarm. Check all the fuses I can find all are ok. Any ideas to wjats wrong any help would help. Thanks
Old Apr 6, 2012 | 01:46 PM
michigan66's Avatar
michigan66
Welcome to FTE. This is a great site for all things Ranger.
Did you check both fuse boxes? There is one in the passenger compartment and one in the engine compartment.
Do you have an Owner's Manual? If so, It lists the circuits each fuse protects.
Auto parts stores, such as AutoZone and O'Reilley's will often help you check things out at no charge.
Let us know what you find out.
Old Apr 6, 2012 | 05:20 PM
nfg's Avatar
nfg
I check all fuses in soclet by test port on each fuse. Pulled each relay 9 total. They all checked out. Any other ideas PLEASE
Old Apr 6, 2012 | 06:43 PM
Phinxter's Avatar
Phinxter
did you pull the fuses and just look at them? I would use a test light and actually verify you have power to the fuses, make sure when you do this you have the igntion in the run position, some wont have power with the key off. by looking at all the wire diagrams for the trouble spots you are having the only thing in common I see right away is the GEM. I'm not a Ford tech so I can't confirm this to be your problem.
Old Apr 6, 2012 | 06:51 PM
nfg's Avatar
nfg
I checked continuity without power with fuses in place. There are 2 small test ports on each fuse all had continuity. If its the GEM any idea where its located ?
Old Apr 6, 2012 | 07:06 PM
Phinxter's Avatar
Phinxter
behind center of dash.
Old Apr 6, 2012 | 08:20 PM
nfg's Avatar
nfg
thanks for all your help, will let you know thw outcome
Old Sep 1, 2013 | 08:49 PM
spinge's Avatar
spinge
Did you ever have an outcome - my son's ranger has done the same thing
Thanks
Old Jan 20, 2021 | 04:38 PM
Jim Zimmer's Avatar
Jim Zimmer
Are you getting power to fuses? there are main fuses. You need a rest light
Old Jan 21, 2021 | 12:30 AM
Big_Al59's Avatar
Big_Al59
Thread is from 2012
Johnny Bravo 45
Electrical Systems/Wiring
Jul 11, 2024 06:17 PM
Jasonpremo
Nov 20, 2013 07:19 PM
nightcrawlermc
Oct 14, 2006 09:10 PM
67stingray
May 21, 2006 09:37 PM
celjel
Sep 30, 2004 06:38 AM
