Sinister coolant filter.
Old Apr 5, 2012 | 11:18 PM
draboo's Avatar
draboo
Easy enough install. Only trouble I had was getting the "bolt" off to secure the bracket for the filter housing. I thought it was a nut on a bolt. DUH!
Other than the brain fart above, I m happy with the quality. I used the teflon tape..somewhere I read where some one used it and had leaks everywhere they used it. I made sure I wrapped plenty around, plus I took out the extra plug and re wrapped it also.
No leaks and everything heats up great. I can see fluid returning to the degas bottle when I peer inside.
So..how long to let it go before changing the first filter? I will be putting probably 1500 miles on it during the move later this month.
Old Apr 5, 2012 | 11:38 PM
phantomphixer's Avatar
phantomphixer
coolant filter
1K miles first one, not much inside go for 6K/6months. If lotsa junk inside 3K on the second. Yearly after that.
Tom14032
May 7, 2015 09:11 PM
TruckNorris
Jan 14, 2012 08:02 AM
grayf250
Sep 6, 2010 05:39 PM
UGA33
Jan 26, 2008 08:18 PM
MLCRI$I$ II
Apr 26, 2007 02:19 PM
