2003 6.0L Engine Repairs and Upgrades - Input Please!
Pics added, starting here: https://www.ford-trucks.com/forums/1...l#post10688008
Well, finally am finding some time to tackle the rebuild of my '03. Any input you can provide on advised upgrades/procedures and best prices would be much appreciated! For those that don't know, I laid my truck over back in November; an unpleasant little escapade that resulted in a locked engine due to oil draining into cylinders while on it's side. The end result was a damaged body and a bent rod (or two). Why am I rebuilding again? (3rd time...) It's an excuse to upgrade and make it more of a dedicated toy
So, this coming weekend I'll be pulling off the damaged cab and starting into the engine to determine parts needed. I'm going to replace only the damaged rod(s) and their bearings, because the rest of the lower end has been rock solid and only has 103k on it. Following that, it will get new headgaskets, studs, EGR delete, possibly a fuel upgrade, and other misc parts.
Here is where I've come to a crossroads, oem or the Black Onyx head gaskets? I'm leaning towards OEM, from feedback I've read of the Black Onyx having a higher failure rate and some builders stopping carrying them for that reason. But, most performance dealers still offer them, and sometimes only list them and not oem, so help me decide!
For studs, I'll be going with ARPs. It won't be an extreme build, and I can't justify the cost of H-11 studs.
Heads and block surfaces will be checked and machined if necessary (as little as possible).
EGR cooler will be welded up. I don't need to spend money on a kit when I can weld and it will keep a stock appearance. I'm tempted even to just do the block off plates and dummy plug since the cooler is still good.
The two injectors I replaced last spring will be relocated to the difficult cylinders (5 and 7) since they will likely last longer than the other six. I'd like to replace the rest, but not in the budget.
Leaning towards a full regulated return fuel setup. Now's the time to do it with the engine out and up-pipes out of the way. I think I would go with the ITP / Strictly Diesel kit.
New oil cooler, even though mine is fine. Advised, or stick with the one I know is good? Also might to IPR while I'm in there, as I've had occasional no-starts where it will crank forever and not fire, then fire right up the second attempt. I think that was a sticky IPR. New upgraded metal HPOP screen of course...
One big question I have, is whether I should do any of the updates the later engines have, such as the upgraded front cover and larger water pump. I'm leaning away from that for cost purposes.
Also, another biggie, is if I should do any upgrading of my '03 HPOP system (stand pipes, logs, etc) or just replace all the o-rings and call it good.
I'm sure I'll have more questions as this goes forward, and it will most likely be drawn out as I'll me doing the work on free weekends at my dad's shop across the state. I'll also post this in a few different forums to get the most feedback, so don't be surprised if you see a repeat.
BTW, in addition to the engine work, it's getting every new body part, except the left doors. Can't find a short bed, so most likely will go with a flatbed. Then possibly cutout flares on the front and a set of 38s
Thanks for any input, and wish me luck!
Wow.....that's a list. Are you sure that you have bent rods? ARP's and stock headgaskets for sure. EGR delete you have is a good plan. Upgrading the HPO system is difficult on an 03 and might be cost prohibitive beyond doing the HPOP itself. O-rings should be sufficient. If you're going to deck the block it will probably have to be stripped to the bare bones and warped blocks are extremely rare. Then you get into another can of worms with cam installation, bed plate, rings, bearings, etc.
Fuel system is a great upgrade. Period.
Absolutely on the new front cover and water pump. IIRC you can get the whole assembly and you should.
Recommend replacing all the Rods in one shot to eliminate that problem
You are doing it right checking BOTH head and block surfaces.
Most people doing a repair check heads, and not block... and not follow the revised TSB.
If you are doing just the head (not checking block flatness) follow revised TSB
Explain to me why some cylinders are difficult.
Pretty good move --- I am isolating a lot of vapor caused problems.
Bulletproof Diesel but you must get the thermostat kit that is "optional"
Not clear if the problem is vapor lock --- see my longish post on that
Brand new water pump is mandatory.
Consider one with a casted / shaped impeller that creates less turbulence than the stock one. New water pump is a real small cost.
The Bullet Proof Diesel FICM is mandatory.
Assuming that Ken can get you on in time.
A few other twists I would consider --- but give me some time to think about it.
I don't like the HFCM much, and am leaning to its replacement with something better --- I also want to see better water blocking / filtration of fuel.
Alternator upgrade -- might as well do it now... figure out your electrical load.
Replace all bad cables / connectors.
Have fun.
Thanks for confirmation on the HPOP system. Why definitely a front cover? I know the newer one flows better and cools better, but I've never had any heat issues and the newer cover is spendy. If I don't do the cover now, I won't do the pump, because the pump can be done later if needed without pulling the engine.
Have fun.
Have fun.
I know about the rod thing. Drove around with one clicking the crankshaft just enough to be seriously annoying for 3 weeks. That sucks for sure but they're not that expensive.
Front covers can cavitate over time PLUS it's a chance to go from the small to large water pump. The covers have come down quite a bit. They aren't $500+ like they used to be I don't think plus I believe they include a new gerotor pump, which you need to replace regardless of the front cover ($30).
The cover is $302 from Tousley. I bet Ed can do as well and save you some freight since he's close.
Pulled off the box and cab, didn't get the engine pulled yet though. I'm leaning towards the black headgaskets since they are quite a bit cheaper and I've really only read of two cases where they failed for no reason, not set on that yet though. Are the intake gaskets reusable, or do I need to purchase new? Any good source for all the needed gaskets for this task or a compiled list I can order from?
Also, I plan to replace all the HP oil rail o-rings too, is there a kit for this for the '03 motors, or do I just need to go to ford and order each one individually?
Still undecided whether to replace the ICP and IPR. The ICP was replaced under warranty before I got it, the IPR I think may be sticky, but there were only a few occurrences that make me think so and it's a spendy part.
Hopefully weekend after this I'll get the engine pulled and torn down.
I didn't but my rod was only tweaked about 1/8". All I replaced was the rod and that was about 100K miles and 2 sets of headgaskets ago.
Some food for thought about buying an unknown/unseen used front cover. If the water pump cavity has scratches or scoring it may be nothing but an expensive piece of scrap cast aluminum. It only takes something like 1/16" to not produce enough flow. Not sure this is something I'd go used on without looking first.
Tore down to just the long block on the frame, removed glow plugs and started turning engine over by hand to feel the rod scraping... nothing. Really strange and has me baffled. When cranking before, it clearly sounded like a rod was scraping internally. Pulled the right head and tomorrow will pull the other and check each piston height at the top to see if there is any evidence of a bent rod. I'm wondering if the oil-locked cylinder just popped the head gasket and what I thought was a rod scraping was actually just air/oil hissing through a gasket leak??? Really strange, hopefully I'll find out more tomorrow.
Also, the first stand pipe bent/twisted removing it, do new ones come with the oem head gaskets? I think I've read that...
