Upgrading my 6.0
Old Apr 3, 2012 | 08:43 PM
viper29's Avatar
viper29
Exclamation Upgrading my 6.0
New to the site.
I have a 2005 F250 with a 6.0 with 130,000 I am the 3rd owner. No real problems I want to replace the oil cooler, the STC fitting, stand pipes, and either replace the EGR cooler or weld ends up, do a EGR bypass or a delete? While I'm in there. A little hard to start when warm. Who has the best oil cooler. IPR is out of there heavy duty ones. Need some advice on what to do and to get replacement parts. Plan on doing it my self. Wanting to fix these things before becoming a problem.
Old Apr 3, 2012 | 08:55 PM
richsoucie's Avatar
richsoucie
bpd for the oil cooler gonna run you about $2300 the ipr ones are junk
Old Apr 8, 2012 | 06:25 PM
viper29's Avatar
viper29
New parts coming
Can't afford that but got OEM replacement oil cooler, Upgrade Sinister EGR cooler with bigger ports. My question is with this new egr cooler what would hurt if I welded up the end that connects to the exhaust. I also got the new STC fitting,new updated stand pipes and dummy plugs., updated turbo in and outlet oil tubes. Figure while I'm in there fix it.
Old Apr 9, 2012 | 02:44 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
i have a IPR oil cooler an im very pleased with it. Its far from being junk as richsoucie says. if its ur daily driver an your not going to be towing alot of heavy loads, i would suggest a IPR oil cooler to anyone.highest oil temps i ahve seen from my IPR oil cooler has been around 235 an that was pulling my 7500 lb camper. coolant temp was around 195. 235 degree oil temp isnt high enough to have any worries at all about.
Old Apr 9, 2012 | 03:50 AM
viper29's Avatar
viper29
You think it would hurt/ help, to weld up the exhaust end of the NEW EGR cooler?
Old Apr 9, 2012 | 10:15 AM
05 f250 6 inch lift
if you have a sinister egr cooler , no need to weld it up. it wont rupture like the factory one will. if you were goin to weld up a egr cooler, should have just kelp factory one or bought a egr delete kit.
but to answer ur question, no it wont hurt to weld a plug in ur egr cooler.
NoAmmo
Aug 9, 2012 04:52 PM
parkland
6.4L Power Stroke Diesel
31
May 31, 2012 03:13 PM
swampfire79
Feb 19, 2012 12:18 AM
Haymanwolf
Sep 22, 2011 11:57 AM
chromedom
May 19, 2010 12:19 PM
