On the bright side the 6.4L oil cooler is plumbed in parallel with the EGR cooler rather than in series like the 6.0L. Meaning that a plugged oil cooler shouldn't destroy your EGR coolers.
Wow, called ford and they don't consider it an issue till theres 30 deg of difference.
He even said they just replaced one, and brand new there was more difference than mine!
I was told maybe use a oil system cleaner and switch to synthetic, but that sounds like it would get really expensive
Park, I just went out for a drive and get everything up to operating temps. ECT=196, EOT=92, TFT=165.
Remember that your EOT temps will continue to climb long after your ECT gets fully up to temperature. After awhile your EOT will continue to climb until it exceeds ECT, and there's where you want to look for the maximum difference. Those numbers you just posted are perfectly normal for a truck that's still warming up.
