Anyone done the bulletproof mods?
Old Sep 21, 2011 | 12:49 PM
Haymanwolf's Avatar
Haymanwolf
My water temp/oil temp split is getting pretty wide and I was wondering if anyone has done the "Bulletproof" EGR Cooler and external Oil Cooler mods on their truck. The cost for the kit is pretty scary, especially since I need a round EGR Cooler. What kind of price would I be looking at if I went back with OEM coolers? They've been pretty reliable for 123K miles. Thanks.
Old Sep 21, 2011 | 12:55 PM
Unrealo4's Avatar
Unrealo4
Round egr coolers don't need to be replaced. Just do the oil cooler and your fine. Its one of the 03 motor perks.
Old Sep 21, 2011 | 12:57 PM
NewToDiesels's Avatar
NewToDiesels
Yep...
I installed both the oil and EGR coolers... Love not having to worry about the oil cooler getting clogged any longer. It's expensive yes, but I did not want to have to replace either one again, so I dove in did it myself. Seeing threads lately about popped oil coolers makes me even happier I spent the extra $.
Old Sep 21, 2011 | 03:49 PM
npccpartsman's Avatar
npccpartsman
The OEM oil cooler can be purchased for about $215 + shipping. Install will be quite a bit more. I recommend you do it before you pop an oil cooler or melt your standpipe.
Old Sep 21, 2011 | 03:53 PM
Haymanwolf's Avatar
Haymanwolf
Can I get a second on this? I don't think I've heard it before.
Old Sep 21, 2011 | 03:59 PM
npccpartsman
I won't say they NEVER need replaced, but they are a LOT stouter than the square ones and very rarely fail. If you're not blowing white smoke then the cooler is fine and it's NOT that hard to pressure test while you have the intake off to replace the oil cooler.
Old Sep 21, 2011 | 04:07 PM
Unrealo4's Avatar
Unrealo4
The round ones were the inspiration for the BPD egr coolers. They are built totally different then the square coolers. They lack the solder that fails because they are welded. If it hasn't failed by now it won't on its own.
Old Sep 21, 2011 | 04:21 PM
rdunagan's Avatar
rdunagan
just get a regular oil cooler. its been redesigned anyways for better flow and as long as you keep your maintenance up ie: oil changes and coolant flushes you will be fine and can go for a super long time!!!
Old Sep 21, 2011 | 04:39 PM
NewToDiesels
If you choose to install new OEM oil cooler (rather than BPD cooler), then also install coolant filter.
Easy and cheap to do...
Old Sep 21, 2011 | 08:43 PM
abealex's Avatar
abealex
My round one went at about 73,000 miles. 2004 with the 03 motor.
I went with the BPD unit. Pricey, but it won't happen again...
Old Sep 21, 2011 | 09:16 PM
joetech's Avatar
joetech
I did the bulletproof oil cooler. It was just piece of mind thing. I work at a dealer and fix cars all day I only wanted to fix mine once. The bulletproof kit was an easy way to guarantee that. I also did a BD diesel egr delete mine is an early built 04 with a round cooler. They make a very nice product with great instructions and tech support plus 3 extra quarts of oil in the system doesn't hurt either.
Old Sep 22, 2011 | 11:46 AM
raptor131's Avatar
raptor131
did u go with the condensor style or just the replacement oil cooler?
Old Sep 22, 2011 | 11:57 AM
joetech's Avatar
joetech
I installed a condenser mount oil cooler.
Nitrodude
Feb 7, 2015 05:56 PM
paultfh
Mar 20, 2014 03:21 PM
run6.0run
Nov 3, 2012 08:01 PM
swampfire79
Feb 19, 2012 12:18 AM
frnkln2003
Feb 14, 2011 09:24 AM
