oil cooler question
Old Feb 16, 2012 | 03:09 PM
swampfire79's Avatar
swampfire79
oil cooler question
I am fixing to delete my egr. Im was wondering if yall recomend changing oil cooler also. Thanks for any info.
Old Feb 16, 2012 | 04:28 PM
npccpartsman's Avatar
npccpartsman
What kind of temperature spread do you have between ECT and EOT?
Here's the deal. If you delete the EGR cooler then you can get away with a larger temp. spread because you won't have an EGR cooler to fail. The thing you need to watch is how high the oil temps get. 254* will cause a defuel. 350 will cause catastrophic failure because the oil filter standpipe melts and runs through the engine oil passages. It's not the oil that fails at those temps, it's the rest of the parts
Old Feb 16, 2012 | 04:30 PM
BLADE35's Avatar
BLADE35
Well whats the ECT vs EOT spread like ????????
If you dont know that^^^^^ then you could be throwing away a perfictly GOOD Oil Cooler
But due to the amount of Labor involved and since the same amont of work is required to get at either one Some folks do elect to just change it
for a couple hundred bucks you may just want to change it out since its not to expensive if you go threw Tousley Ford
Old Feb 16, 2012 | 06:43 PM
swampfire79
I have no way of checking the spread. Origanly i was thinking of buying the sinister with set x3 but now thinking of buying the kit that includes the oil cooler.
Old Feb 16, 2012 | 09:25 PM
HP junkie's Avatar
HP junkie
I would get the BPD condenser mount oil cooler. My brother just did it and is pleased with the results.
Old Feb 16, 2012 | 09:32 PM
ajwelds's Avatar
ajwelds
If your pulling the egr the cooler needs replaced especially if you haven't done the coolant service. The BDP is great but too pricey for most. Try United Ford 1 (800) 677-2277, ask for Randy Mac. Great service & prices to match. Ship all over from Oklahoma.
Old Feb 16, 2012 | 10:24 PM
jl4407's Avatar
jl4407
I just did my egr delete and oil cooler, finished it tonight. It wasnt to bad..
So with a egr delete you can have a higher ect and dot spread?? Not that I'm planning on it with a new oil cooler but it would be nice to know!
Old Feb 17, 2012 | 08:01 AM
raptor131's Avatar
raptor131
welcome to the dark side! I know you are asking yourself how did i ever drive a 7.3 when it lacked so much power. LOL did it fit in the garage?
to the OP if the pocket book allows, the bpd unit is the best thing out there, but it is cost prohibitive for most on a budget, with the labor involved i just didn't want to tear that deep for the same thing. buy a scanguage 2 so you can monitor the spread going forward
Old Feb 17, 2012 | 08:45 AM
HP junkie's Avatar
HP junkie
Like a glove on OJ. It was tight but with a few mods to the workbench she'll fit great.
Old Feb 19, 2012 | 12:18 AM
stroked4life's Avatar
stroked4life
oil cooler
do yourself a favor and install a coolant filter, that will keep the oil cooler from plugging up. Sinister sells a nice kit for $125 and it really does install in minutes
Aune163rd
Apr 28, 2015 02:36 AM
Nitrodude
Feb 7, 2015 05:56 PM
anassar11
Apr 5, 2012 01:46 PM
Haymanwolf
Sep 22, 2011 11:57 AM
chromedom
May 19, 2010 12:19 PM
