Appears the sensor circuits could be out of range. The first thing I'd try would be to clean the egr to make sure it has full travel. Cleaning procedure should be in the tech folder.
Those are EGR codes. Did they just pop up or were you towing up a long hill? Need some more info. I had the same thing. FoMoCo changed oil cooler under warranty and after the warranty I still had them during long uphill pulls. Started with a CEL(check engine light). Deleted EGR valve and cooler. Bought a programmer to cancel the EGR valve removed lite. Still have the EGR valved plugged in though. Runs like a scalded ape uphill, as in towing 8K toy hauler it will accelerate. No codes in appx 9 mos.
no i dont toy anything heavy and i live in fl not alot of hills here!!! lol my truck only in the morning time or after its been sitting for a long period would run sluggish in the morning and then after it heats up it would run fine!!
well i removed the egr this morning and it was pretty clean cleaned it up a lil but my truck still runs a lil sluggish in the morning time!! if i bought a new egr would that fix my sluggish problem in the morning??
