66 f100
Old Mar 31, 2012 | 06:54 PM
stallion3599's Avatar
stallion3599
I have found the number on a place that does carter carbs it says the kit is ck238 and the float is f 17. Does this tell you anything? It says you can order kits off the site.
SP
Old Apr 1, 2012 | 05:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
SP
Neither of these numbers are Ford related. Auto-Lite & Motorcraft carb kits have a part number prefix of CT. There is no CT238 carb kit listed for this application / The floats Auto-Lite/Motorcraft part number prefix is CM
1973 and later: The ONLY way get the kit part number: Using the carb ID chart, the carb ID tag number decodes to the carb and carb kit, lists the carb parts list.
The carb kit is not listed in either the carb application charts nor the carb parts lists. Since you haven't the carb tag number, I cannot look up the kit, nor the float.
Back to square one.
I have no idea if a replacement aftermarket carb is available or not, or even if one was ever offered. I never dealt with aftermarket parts when I was working as a Ford partsguy (retired 8/1997).
Old Apr 1, 2012 | 12:59 PM
stallion3599
I am going to keep digging, any carbs on the market right now that will fit my 6 banger?
66 I guess 3.9?
SP
lazzarruss
15
Oct 30, 2013 08:59 PM
Jeff L. Davidson
May 18, 2012 03:40 PM
Dean88
Feb 14, 2008 09:36 PM
nuwave
May 12, 2007 03:06 PM
kooper909
Jun 1, 2005 07:23 PM
