Carb Serial Number?
Old May 9, 2007 | 08:22 PM
nuwave's Avatar
nuwave
Carb Serial Number?
I need to replace my carb and was looking on LMC for a replacement. They have alot of choices for my truck, but essentially only sell 2 if I just go by their part#. I need to locate my carb serial number so I order the right one and do not know where the serial number is. The Motorcraft carb does have a tag w/the following info:
D5TEASA B 6D 9
I figure this is only a Ford part no.
Old May 9, 2007 | 08:36 PM
Mil1ion's Avatar
Mil1ion
You probably have either a Ford 2100 or 2150.
They are actually called: engineering numbers
Yours is D5TE-ASA
You should be able to get one locally at a parts store nevermind LMC.
It takes rebuild kit CT-1077D
I can get you a Motorcraft service Carburetor number if you wish.
CA-1533
This carb was used on numerous engines for numerous years.
It should be fairly inexpensive.
Here is one at Rockauto ...an FTE sponsor.
http://www.rockauto.com/catalog/x,ca...,parttype,5904
Old May 9, 2007 | 09:23 PM
rusty7983's Avatar
rusty7983
those carbs are very easy to rebuild. buy a kit and do it yourself. it will save you some $$ also.
Old May 10, 2007 | 03:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TE-ASA B 6D 9I figure this is only a Ford part no.
D5TE-ASA = Ford carburetor ID tag number = D5TZ-9510-AS (Motorcraft CA-1313)
Old May 10, 2007 | 08:30 AM
Broken40's Avatar
Broken40
My advice to you when rebuilding that carb is........take your time. The only way you can screw one of those carbs up rebuilding it is if you don't take your time, i know from experiance, not measuring the floats and tightening all the screws and puting the ball bearings back in the right spot can really **** a guy off when he goes to start his rig after rebuilding a carb......again please take your time, don't get in a hurry.
Old May 10, 2007 | 09:48 AM
nuwave's Avatar
nuwave
I am not going to rebuild since the carb is cracked and warped. All parts houses I looked at, including rockauto, list 2 carbs that could be used (2100d or 2150). I do not know which one to get; they look the same.
Old May 10, 2007 | 11:26 AM
Mil1ion's Avatar
Mil1ion
The 2100 was more reliable than the 2150, but the 2150 became the Ford standard 2v.
IMO, Go with the 2150
Where do you live exactly?
Any parts house can get you a carb locally.
The problem with rebuilding an ols carb is the shaft bushings wear out and they don't come with a rebuild kit..so it would cost extra money and time to bring an old carb up to snuff.
Just get a rebuilt one from a reputable parts house.
Old May 11, 2007 | 09:06 AM
Broken40's Avatar
Broken40
I wouldn't tell ol' mil1on where you live he may come and rebuild that cracked and warped carb..........beware of this man...........muaaaaaa...lol. just kidding.
Old May 11, 2007 | 09:15 AM
NumberDummy
The number you posted >>> D5TE-ASA IS the carb ID number. That tag number is what tells the Ford or garage mechanic working on it what carb it is, and gives the correct carb parts list and carb kits. Finding an original tag number on a carb is rare, most are missing today.
Old May 11, 2007 | 12:08 PM
Broken40's Avatar
Broken40
If you don't mind me askin, why don't you get an eddies or holly to put under the hood of yer beast....or just plain aftermarket?
Old May 11, 2007 | 12:23 PM
Mil1ion's Avatar
Mil1ion
He is in Florida so I figured he must be near an auto parts store
Maybe he has a jet boat and lives in a swamp
Old May 12, 2007 | 09:41 AM
Broken40's Avatar
Broken40
There ya go, nothing like jettin thru the swamps to find some good ol' ford parts.
Old May 12, 2007 | 03:06 PM
nuwave's Avatar
nuwave
Thanks 4 the help. I do live by many parts store, but they are a PIA about some parts. I have already lived this carb problem with my 66 f100. There was only 1 carb for it and I ordered it online, no running around wasting gas. I did the same here from rockauto. Never used them, so we will see.
Larry Heath Wheeler
Oct 16, 2015 07:36 PM
twinzilla
Dec 1, 2011 09:32 PM
drewdog
Jul 24, 2009 10:10 AM
1997stroker
Jun 26, 2007 05:38 AM
Cy
Sep 1, 1999 05:45 PM
