D8TE carb part # questions (and links)
What do the letters after the part number mean?
Carb Numbers:
D8TE-XXX
D8TE-DA
D8TE-DBA
D8TE-CJA
D8TE-BEA
D8TE-CPA
What is the difference?
Also some links that have provided me some useful info in regard to Ford Part numbers:
http://www.carburetion.com/fordnumber.htm
http://www.carbkitsource.com/carbs/catalog/FordTruck/<O
Carb Numbers:
D8TE-XXX
D8TE-DA
D8TE-DBA
D8TE-CJA
D8TE-BEA
D8TE-CPA
The carb tag number identifies exactly what carb you have.
In the Ford parts catalog there is a list of the tag numbers and it will tell you what the correct carb kit is, it also tells you the part number of the complete carb.
There is no way to tell what the differences are between different tag numbers. Sometimes its easy, example two carbs both have a D8TE prefix. Ones a two barrel motorcraft, the other a 1 bbl Carter. but if both carbs are say Motorcraft 2150's, both have the same prefix but one has a -ATA suffix, the other a -DB suffix. What's the difference? No easy way to tell. It may not be anything that you can tell by just looking at it.
another link for part # info
So After looking at this I think I do not have the full part number for the Carb I need.
Decoding Ford casting part numbers
The actual part number im looking for would be between 9500 and 9599.
Every time I start reseaching somthing and find some info, I think Im almost there...Just find out Im barely uncovering the tip of an iceberg.
Any help narrowing down the part number I need would be great.
Truck info:
1978 F150 Ranger XLT, 400, built in San Jose, ordered from Pheonix
factory A/C, C6 transmission. Emissions Calibration 7-74-R10.
looking for the right part number for the. PO put a different carb from a newer model truck.
Truck info:
In other words unless I had the original carb I may never know exactly what I had.
I may be making this bigger in my head than it needs to be. Im pretty sure I am.
I am trying to collect all the info I can to determine the type of choke, anti diesel positions, vacuum setup, wiring etc I am supposed to have. I was hoping the carb part number would help. Most the sites im finding give either very little to no info; or an overwhelming amount of info. There are too many disconnected tubes, wires and connectors on my truck and not enough conclusive info. So close on many things but not quite there...
Yes its a variation of the 2150, but the guy I bought the truck from told me its from a newer model. He said there are some "features" that may not be hooked up.
I like things to be hooked up. I figured if I understood what my truck had in it, then I could figure out what the accessory systems should be, and be able to buy the parts I need to bring my truck back to stock.
Thanks
Fits:
78 F150/250 w/ AT 400 & Calif Emissions before s/n BA0,001
tag D8TE-BA p/n D8TZ-9510-B
from s/n BA0,001
tag D8TE-CRA p/n D8TZ-9510-L
tag D8PE-APA p/n D8PZ-9510-AP
I'm guessing on the Cali emissions because it was built at San Jose. If the emission label is still on the engine it should specify Cali or 49 state emissions.
I don't have a chart that breaks down the calibration codes.
ive seen a few charts floating around that show what my code is, but none showing what the 7-74-r10 calibration details... Ive seen drawings for many other calibrations though. I hope i run across the drawing for mine. does not seem like ill find it online though. Im hoping my trip to the library will yeild results.
Yes, the serial number is the last six digits of the VIN.
assuming the sticker on my valve cover is original I have a non-catalyst setup. Does that also mean I probably didnt have the vapor canister as well?
if there were no atalytic converters it would seem like they would not. There no return line to the fuel tank either. I actually have two fuel tanks but due to rotting hoses the PO rerouted the lines and cut out the rear tank hoses. So I have only one operable tank now.
