Need help decoding Autolite carb
Old Feb 13, 2008 | 02:15 PM
Dean88's Avatar
Dean88
Well I got a free 2bbl carb off of an old Ford (presumed to be 67-72)
The tag says: Autolite
C7TF E
A 6HC
Any ideas?
Old Feb 14, 2008 | 08:28 AM
sleep_deprived129's Avatar
sleep_deprived129
67-72 is probably a Holley 2100
Old Feb 14, 2008 | 02:06 PM
Dean88's Avatar
Dean88
The tag says autolite
Old Feb 14, 2008 | 02:48 PM
Freightrain's Avatar
Freightrain
C7 is 1967. t= truck, F= engine accy. The "E" is probably revision number?
The rest I suppose are application numbers?
Where's Bill when you need him? He's the resident part number expert!
Old Feb 14, 2008 | 08:19 PM
dbossman's Avatar
dbossman
Autolite decode
C7TF E
A 6HC
Any ideas?
C7TF = 1967 Truck (I don't have specific listing for this so I can't tell you exactly which engine size it was designed for, but I would guess 352 v8)
A: references the design change (in this case, the first iteration of this carb)
6HC: is the date code 1966 - August - 3rd week
If you can tell us what the raised number is just above the accelerator pump rod, on the side of the housing (ex. 1.12, 1.08, 1.23, ...), I can tell you the CFM rating.
Tim
Old Feb 14, 2008 | 09:36 PM
sleep_deprived129
Yes, well from wut I know Holley made te carbs on these trucks for Motorcraft/Autolite, so it will be equivalent
ClatonK
Feb 11, 2019 07:09 PM
Nick-1973-ford
Jul 9, 2016 09:25 AM
hooler1
Jan 16, 2016 08:52 PM
53rmod
Dec 3, 2015 08:55 PM
jzzzake
Jun 20, 2015 10:43 AM
